Question about Maytag MSD2756G Side by Side Refrigerator
Jenn-Air JMW8527 Light in Control Panel not working
I have a Jenn-Air JMW8527 Electric Wall Oven. The light in the control panel doesn't work. I can't see temperature settings, clock, timer, etc. The oven light is working. I was told I need a new board? Could there be a bulb that needs replaced? If need a new board where do I find the number of that part.
Thanks
  • Anonymous Apr 03, 2009
    we have the same model and problem--the temperature display is dark and cannot see the temperature reading. the time reading is barely visible. otherwise, the oven works fine. any ideas what the problem is?
SOURCE: I was baking in my
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Posted on Jul 12, 2008
SOURCE: electriic oven control broken
maytag #mgr4452bdw the clock will not set the face reads 5-A-6 and the oven will not come on
Posted on Oct 10, 2008
localwonder
  • 6784 Answers
SOURCE: control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
Posted on May 25, 2009
localwonder
  • 6784 Answers
SOURCE: I have a Maytag in wall oven (part# MEW653ODDS).
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Posted on Nov 03, 2009
SOURCE: Some numbers on panel does not work
I have the same problem. I can't see how maytag can say there are no quality issues since they don't track how many calls they get about the same problem.
Posted on Nov 28, 2009
Oven light stays on all the time
Did you try the light switch on the control panel? If it's turned on, the door plunger will not turn the light off.
Oct 01, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Control panel light is extremely dim
Should be C3 Capacitor on control panel board replace capacitor from Digi-key Corporation get panel out and see what C3 capacitor says what voltage and uf and temp celcius and order from them solder it takes two -10 minutes..
Apr 19, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air wall oven control panel not working
my jenn air wall oven controls are not working how do i fix it
Nov 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air JJW8530 LCD panel does not light up
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Oct 08, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I HAVE A W136C Jenn-Air wall oven and would like a wiring connection diagram. Icant figure where to connect the orange wire
Look for schmatic behind control panel, open oven door and remove 4 screws that hold upper face panel down, panel should slide up 1/2' or so and lift off.
Sep 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
My Jenn Air Electric Wall Oven Control panel lights have gone out
You will need to replace the display assbly.
It is a very common problem with maytag/Jenn Air
Feb 19, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-air jes9800AAB keeps buzzzing, front function panel flashes on and off
Your control panel is getting ready to quit. Mine did the same thing, I ignored it and now nothing on the touch panel works. About $150.00 for the part.
Jan 14, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Maytag MSD2756G Side by Side Refrigerator Logo
155 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
