Question about Bosch & Tankless LP Hot Water Heater
Bosch Eco 5 Igniter keeps clicking
The igniter keeps clicking, there is no demand and burners don't go on. When hot water tap is turned on, it operates correctly, but then when water is turned off it starts up again. I changed the batteries, thinking that might be the problem but no help. It just keeps clicking away as if it is trying to ignite.
  • doctorrae Mar 15, 2009
    Thank you earwel, I am sure you are right, in the meantime, after I tapped all the connections, the unit has stopped clicking so I will ignore it until it starts again
  • 234 Answers
You have sense bad on the unit.
Posted on Mar 15, 2009
  • Earnest Bowes Mar 15, 2009
Bosch gwh 425 hn
Fix problem immediately same day, yourself, for $385, by replacing whole thing:
Bosch posts some service manuals: or contact Bosch. Lack of error code indicates failed PC board? or bad single-handle faucet cartridge?
Check for crossover where bad faucet cartridge allows cold water to enter hot pipe, so hot water is not drawn through tankless and burner does not activate... but this might not be problem since you hear the tankless clicking
Call local service technician to catch up on required yearly maintenance.
Jun 09, 2013 | Water Heaters
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
We have a 10 year old Rheem PVW50 Power Vented water heater that works on gas. The last couple of days it has been giving out problems. It will not maintain hot water in the tank. I restarted it and...
The igniter is glowing, but no gas ignites?
So either the gas is entering combustion chamber and not lighting because igniter is positioned incorrectly -or- no gas is entering combustion chamber because air in gas line or bad gas control valve thermostat or gas line is clogged.
When you 'restart' the water heater, somehow you are getting gas to the burner and it is igniting.
I'm not sure what the flame switch is. If the ECO was cut out, the gas control valve would not send power to the igniter and there would be no gas available for 'restart.'
I would adjust location of igniter, check if gas is entering combustion chamber, clean the gas line to the burner, and bleed gas line for air, but another suspect could be the gas control valve thermostat.
Identifying numbers are usually on side of gas valve.
Open following link to help identify gas valve:
Jul 02, 2011 | Rheem Water Heaters
I have a Bosch tankless propane water heater 125fx. Yes, I know it's ****, we replaced the igniter switch last year. Then struggled with ordering parts to repair a water leak. During the leak, it was...
There is likely an onboard relay stuck in the open position.
This is a gas appliance and should be serviced by an authorized BOSCH repair center to avoid potential catastrophe.
Aug 06, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Demand light not on when hot water tap is turned on, so ignition light is not operating.
What has happened is your starter that senses the pressure, and that sensor when activated, , then ignites the igniter, and the heater works. What happens is this sensor/Valve, goes faulty, and it will not work.It must be replaced. Sometimes too, it is the actual igniter itself, you will have to troubleshoot to see which part it is, it maybe easier to just replace both. have a look on the 'net, for a service manual for your system, it will give you a diagram and all servicing data etc. really you cannot repair anything without one. If in doubt at all though. You should contact a professional, and ask for a 'Quote" for the repair.
Jun 01, 2010 | Bosch Water Heaters
Electronic water heater burner often won't light tho pilot's on
it sounds like you pilot lite is to far away from the burner, make sure that the burner is sitting in it;s purch, look thru the site glass it can be moved by hitting or bumping into the out side of the gas tubes on the outside of water heater, if not, the burner assembly may have soot on it. you might also want to make sure the filters are not clogged on the shut offs that will give it less pressure then it needs to make the unit come on,, write me ,
May 15, 2009 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Bosch AQ 125XNG water heater burner frequently won't light
May be That we have something we can try. first, what doesn't work most of the time? Blowing with all you mite or jumping out of the way before your hair gets singed?
I think it sounds like you might have a maladjusted ignitor. Mispositioned. Its not in the gas path. Sometimes this happens as the tungsten ignitor wears down. That can be adjusted by repositioning the ignitor so it is in the pat of the gas. Just don't test as you go. Set the ignitor so the arc is about 1/4 inch long and about 1/4 inch away from where the gass comes out. Keep clear of the access hole. The longer it takes to ignite, the more gas build up there is. Have your exhaust vent checked. restriction keeps it from drafting and drawing enought air to balance the air gas mixed to ignitable.
Be careful and be safe
Bosch & Tankless LP Hot Water Heater  Logo
279 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
