Question about Exercise & Fitness
Treadmill - Everyoung model EY88800K Programmable
Treadmill - Everyoung model EY88800KF Programmable Motorized Treadmill. I zapped the display with static electricity when i went to turn it off. This made the entire treadmill inoperable. Any hope of fixing?? The Company is out of business.
From where I can buy a display for my motorized gear life treadmill ?
It may be difficult to get a replacement display. Have your manufacturer make and model information and contact one of the following:
http://www.treadmilldoctor.com/?gclid=CjwKEAjw65GqBRCj3fLFwK2SpWoSJABa3E3cNMqfrd6JPyfCBK0YWVUETk10Y-O_z8VSOP3fPq-z7hoCZ17w_wcB
http://www.fitnessrepairparts.com/
May 02, 2015 | Exercise & Fitness
Treadmill owners manual
hi im looking for a owners manual for my body science breeze treadmill motorized model number e-4269a so i can work out how to used the programs on it
Jan 01, 2014 | Exercise & Fitness
Everyoung treadmill 86800
see the video attached. and lube the rollers bearing front+back.
God bless you
Oct 18, 2013 | Exercise & Fitness
Looking for owners manual for everyoung 86800F model
go for free download: www.fitness.manualsonline.com or www.manualsfactory.com or www.retrevo.com
sincerely. God bless you
May 07, 2012 | Exercise & Fitness
How do I lower my Everyoung 86800F treadmill from a vertical to horizontal position ?
This might be of a little help. My treadmill is not an everyoung but on the control panel it has two buttons which are used for adjusting the position. While i was searching for a solution on this i came across an individual whop has one for sale you could call him and find out if you are in the US here is a link to his advert.
http://fayar.craigslist.org/spo/2036394410.html
Hope this solution has been helpful?
Dec 10, 2010 | Exercise & Fitness
EverYoung 75900 needs to be reprogramed Display unit show F1 can you pls provide the code thanks Joanne Pekar
I have a problemwhen i start the ever young model 75900F
on screen F1
please send me solution
Nov 05, 2010 | Exercise & Fitness
The belt on my 68600F EverYoung has quit turning. The display screen is still on and says E2.What does that mean? gaylesues@hotmail.com
e2 normally refers to error in the speed sensor - iff the treadmill starts moving and then stops it is speed sensor related, otherwise if it never starts at all you will need to test your drive motor with an external 18v battery (cordless drill battery) to see if the motor will still turn. if it still turns then that narrows the problem to the motor controller which also means that the motor relays are not working and the controller would need replaced
Aug 04, 2010 | Exercise & Fitness
Have the same problem with my Everyoung Treadmill EY88800K. Display was zapped with static and treadmill became inoperable. Great condition and hate to toss out. Any hope?
End up dismantling the unit and disposing everything except for the motor and belt and rollers. Was a good machine except for no parts support.
Dec 28, 2009 | Exercise & Fitness
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
374 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
