Question about Electric Circuit Breaker Kit for Furnace
Black wire to eliment burned off running on one eliment
  • 21 Answers
Hello, You can try re-terminating the connector with a crimp on style connector. Just make sure the wire going to the element is in good shape. If the calrod heater element has shorted out it may burn the at the connection again. If not, you have fixed it! Good luck...gary
Posted on Mar 13, 2009
Brake lights and Rear turn signals
these bulbs have two seperate eliments to burn at different brightness. it is possible that one eliment is burned out. it is also possible that the bulbs are not seated properly in there sockets.
Feb 11, 2014 | 2004 Chevrolet Impala
Replaced thermostat and heating eliment still not heating up dryer runs and blows ari just not heating up.
ALWAYS UNPLUG DRYER BEFORE CHECKING
1.loose wiring---check terminals & wiring
2.defective centrifugal switch in motor---replace switch (check linkage to motor
3.defective timer---replace timer
4.open heater element---replace heater element
Jul 31, 2010 | Whirlpool Dryers
Tail gate light constanly on
Recheck the fuse or just replace it if this circute is fused,
I have run across fuses that have had a hairline break and look ok.
Also check your wiring connectors for corrosion.
May 20, 2010 | 2006 Honda CBR 125 R
My 94 altima has a problem with the headlights . Sometimes they are fine and other times only one works in high beam only .
chances are the bulb is burning out.The wire eliment is bouncing around and making contact.
Feb 23, 2010 | 2004 Nissan Altima
How do i replace the heating eliment? frigidaire fde336res2
i don't know what model You have so i will give you this link appliance repair video’s
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
Dec 29, 2009 | Dryers
Questions regarding an outside mirror
Heated mirrors have a swtch in the car. That operates the eliment that is stuck to the glass.This eliment heats the mirror when turned on.It is used to defrost or demist the mirror.A none heated mirror has no wires going to it and no eliment at the back off the glass.OK.
Aug 01, 2009 | 2004 Nissan Maxima
Free standing kenmore dryer series 90 floor model not stacked not drying
Could be the heating eliment..
A way to check it ---
remove the exaust hose..
Put a mirror to the exaust hole trying to see inside to the eliment(s)..
When running - the eliment should glow hot..
If its not - it migt need to be replaced..
Hope this helps !!
rate me good ;o)
Jul 13, 2009 | Kenmore 98702 Stacked Washer/Dryer
Wirlpool dryer heating eliment keeps braking
Sounds like you use dryer sheets. If you do, try cleaning your lint screen with vinegar. Dryer sheets leave a film on the screen that the dryer eventually can't breathe through, the dryer overheats and burns up the elements.
May 26, 2009 | Whirlpool LER5636P Electric Dryer
No water at all coming from the hot water (electric) tank? we drained tank in case there was an air leak already. If we wait awhile it will run again for a bit then stop --no reason to it. Help please with...
If it is at least a 30 gallon tank it has two thermostats  One behind each door. They are ajustable and you should  be able to cycle then on and off with a small screwdriver. Went finished,if they both worked set them on the same value. With a volt meter,if test lamp,see that you have rated  voltage coming into the tank.   Turn off the electricity, Disconnect the wires for the heater eliments (one behing and usually placed under the theromostates and  the with a battery type test light, if you have not an ohm meter .  Check across each one. Light should light dimly. Brightly means that the eliment is shorted . No light indicates that the eliment is open. No or bright either one replace the eliment. That is about all their is too it . Fairly simple design.
Mar 01, 2009 | Premier Watts Two-Chamber Tankless...
Intertherm furnace mac2460 heating eliment continues to heat
Sounds like a bad blower relay,intertherm will sometimes use a control board
Jan 15, 2009 | Heating & Cooling
Electric Circuit Breaker Kit for Furnace Logo
101 people viewed this question
Top Electrical Supplies Experts
ashburton
Steve
epangan29
Are you an Electrical Supply Expert? Answer questions, earn points and help others
