Question about Welding Tools
Engine surge when ground hooked up / not welding good rods stick
This unit has an engine surging problem when ground is hooked up and nothing else is plugged in only ground. unit is in back of truck on wood pallet not touching anything welding rods keep sticking and not welding good let a friend use ( I KNOW ) suitcase with fluxcore wire and he shorted gun had to buy new gun and seems to be when problem started I'm on the big Island of Hawaii and the only repair is to ship to oahu would rather fix my self I'm sure it just something in cuircut board just need to know how to test and if anyonelse has had this problem.
  • indtech May 11, 2010
    What model machine, sounds like the output is grounded.
  • 58 Answers
Hi rule 1 NEVER let any one else use your set the set is testing itself and by surging it is telling you it has a diode /or more than 1 shorted out locate the diode assembly dissconect it /remove it disconnect and test each diode individualy /insert the blown diode into your friend !!! silk090
Posted on Oct 24, 2009
We had an electric outage last night and now our Intermatic Digital Timer Model PI353ME for our pool will not work. What can we do?
Try the small round reset button top left, and then re-program:
Manuals, including troubleshoot pdf, and wiring on following link:
http://waterheatertimer.org/Digital-control-centers-and-manuals.html#PE153
Install type 2 whole house surge protector or type 1 surge arrester to protect timers, lights, electronics. Make sure household grounding is appropriate, bond outdoor equipment to a ground wire that goes into dedicated ground rod:
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Dec 18, 2016 | Intermatic Hardware & Accessories
When and How Should a Surge Protector Be Used on a Fixed Switch?
Common Causes of Lightning Strikes
  • Outdoor network cables or power cables are routed overhead.
  • A switch is deployed outdoors but is not properly grounded.
Damages of Lightning Strikes
  • If power cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn the power supplies.
  • If network cables of a switch are routed overhead in an outdoor environment, lightning strikes may burn interfaces of the switch.
When a switch undergoes lightning strikes, overvoltage is induced by lightning on network cables and transmitted to interior of the chassis. The surge protection measures, such as lightning rod and chassis grounding cannot prevent the damage. Therefore, surge protectors or surge protection circuits are recommended.
Surge Protector Use Precautions Take the following precautions to protect a switch from lightning:
  • Ensure that the ground cable is connected to a ground bar or a ground point on the cabinet.
  • Avoid routing cables overhead in an outdoor environment. Bury cables underground or route them in steel tubes.
  • To protect network interfaces against lightning, use 8-line surge protectors (or Huawei certified 4-line surge protectors).
  • When installing a network interface surge protector, connect the IN end to terminals and the OUT end to network interfaces of the switch.
If a fixed switch is installed in a network box, follow these instructions:
  • Connect the ground cables of the switch and surge protectors to the ground bar in the network box.
  • The maximum length of a ground cable cannot exceed 40 cm, and a length of smaller than 15 cm is recommended.
  • If the network box is located outdoors and power cables are routed aerially over a long distance (more than 300 m) to the network box, it is recommended that you install a power supply surge protector in the network box. The decoupled power cable must be at least 3 m long
S2300 Switch Thunder link com
Dec 08, 2016 | Office Equipment & Supplies
During a lightning storm my TV went off and won't come back on.
It's called a "power surge," and the only way you can prevent a power surge from destroying a television completely is to use a SURGE SUPPRESSOR, and make sure that the grounding for your electrical system is optimal (meaning at least THREE TRUE GROUND POINTS, usually GROUNDING ROD, GROUND MESH, and PLUMBING GROUND). Consult a qualified electrician.
Sorry for your loss!
May 13, 2015 | Panasonic Viera TC-P50U2 50" Plasma TV
Lincoln ac/dc 125/225 stray voltage question.We changed the aluminum transformer out for an older copper one because it was weak and the ground would bite you.
The shock can be caused by numerous issues such as high humidity, bad ground connection at the case, etc... the suppressor board is just another name for a surge protector, if it is bad, it could bleed current through the ground clamp
Oct 07, 2014 | Welding Tools
CM-7777 Not Working
it may have taken a surge of power and fried one of the amps inside nothing to do but replace it. make sure that your main cable line to your house is grounded very good to a good earth ground source like a ground rod or gas line or cold water line.
Aug 21, 2014 | Channel Master TITAN 2 VHF/UHF...
John Deere 430, Sundstrand series 15-U hydrostatic transmission. The tractor, at low ground speed, surges as it moves, in both forward and reverse, at any engine speed. At full ground speed, the surging...
you sure your engine isn't surging... you would see it at lower speeds... my motorcycle surges at a certain rpm due to fuel ratio's at the one speed ( running lean )... so what i am saying is, could it be that the engine surge only shows itself at a certain ground speed.
or is it because of a hydro system pressure relief valve ???
Oct 08, 2013 | Garden
Rod sticking
make sure you have a good enough ground on your work-piece. try putting a chunk or strip of metal on or closer to your work-piece to get better current.
Apr 28, 2013 | Lincoln Electric Welding Tools
Power surg cannot get washer to power onnow
You may have damage to the control circuit board.
If it's still under warranty call the MFG.
Before you use it again check the ground on the circuit the washer is plugged into. If your in your home, go outside to the electrical meter.
Look around on the ground under the meter for a ground rod sticking up a few inches. Clean the grass away and see if the clamp that holds the wire to the rod can be wiggled by hand. If it's loose get it tightened. It the clamp is busted or the wire is cut or loose. Call an electrician to have it fixed. Also ask the electrician to check if the plumbing is grounded. Bad ground connections make power surges worse.
Jul 11, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Computer will not turn on. Possible power surge.
If the power supply is good then your motherboard must have gone bad during a surge.
Dec 26, 2009 | Intel D865PERL Motherboard
Engine surges. Idles good. sitting still in park, rev the engine and the surging is very evident as when driving. Fuel filter has been changed
hook a vacuum gauge to the intake manifold and, check for a vacuum leak in vacuum hoses and, fittings
Jun 01, 2009 | 1988 Chrysler LeBaron
Welding Tools Logo
79 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
