Question about Karcher K2.26 Electric Power Washer
Worked well, then blew the fuse.
Assuming the fuse blew because the motor (or extension lead plug) got wet, I allowed it to dry out for a week, but today I tried to start it up and it blew the fuse straight away. What should I do next?
  • 389 Answers
What you should do next is stop using an extension lead. As you've already discovered, there's a risk of the connection getting wet, which is potentially very dangerous, but this is probably not the main problem. Most extension leads (the normal domestic type) are simply not capable of carrying the current needed to run your pressure washer.
Rather than using an electrical extension, use an extension high-pressure hose and work further away from the machine (which also makes it easier to keep the machine dry).
If this doesn't sort the problem, please post here again and we'll try something else.  Good luck!
Posted on Mar 14, 2009
Treadmill got wet and blew
Dry it - thoroughly! - a week in the warm! - replace fuse and try - watch out for shocks! - Wear gloves / use a stick
MOST LIKELY - the control board is terminal toast
Dec 25, 2013 | Garden
Main fuse tripping
remove the cover from the heater spray with wd40, wipe dry, replace the cover and re-try
Dec 15, 2013 | Computers & Internet
Breaker kicks off as soon as switch is turned on
the gfci is defective from moisture even after they dry they can be defective,access the cord inside the machine and try a different cord and see if this is your problem,otherwise the pump motor could be bad,the bypass valve on the pump could be bad,if you could run it you could check current draw with an amprobe,but not if it wont start
Apr 06, 2010 | Karcher K2.26 Electric Power Washer
My clarke compressor keeps blowing the fuse in the plug on start up. any ideas!!!! i`ve changed the lead and plug
if the compresor is tight it would blow fuses, or the starter capasitor is leaking,,, (below power)
but its more likley you are using the compresor on a long extension lead and the power drop in that lead is causing the problem,,,if this is so,, use a much thicker extension lead...2hp motor = 2600 wats? at start up,
Oct 28, 2009 | Clarke Power Products AC2002A 2 Hp Air...
Hoover floor mate/ wet/dry I added the water and turned on and no water is coming out? What did I do wrong, I dont have a manuel
I have had the same problem. I took the darn thing apart to see if the hose was loose. Come to find out that when you fold the handle there is an extension that sticks out. This extension pushes down on a plunger that allows the water to squirt out. My extension has broken off some how. I believe this to be a manufacturer defect.
Aug 11, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
check blower motor/ if bad replce motor and blower resister together, check ac fans and colling fan relays,ac clutch could be shorting out also hope this helped
Jun 30, 2009 | 2000 Volkswagen Golf
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Car will turn over just not catch and start
turn the engine over for at least a minuit in 2 or 3 intervals. (NEVER HOLD THE STARTER MORE THAN 25seconds at ONE TIME) pull out a spark plug or two and see if their wet and smell like gass, then you know if its getting fuel. You will need a long 3/8'' extension cuz its overhead cam but the front plugs are easy to get to. If the plugs are dry then pull all the plugs and poor no more than a 1/4 ounce of clean gass in each cylinder of your inline 4, reinstall each plug as you have added fuel connect the plug leads again and start it. if it starts momentarily you've varified the proplem. If the plugs were wet apone the first test verify you have spark, pull one plug & reconnect it to the plug lead touch the bottom of the plug to the engine block (away from its hole) and get some one to crank the engine darker the environment the better and look for a brightblue spark it should be their on all leads. Hope you find somthing
Dec 27, 2008 | 1995 Suzuki Sidekick
Karcher K2.26 Electric Power Washer Logo
243 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
