Question about ASUS P4P800-MX Motherboard
I want to use another video card
How do i turn off the on-board video so I can use another video card
  • 170 Answers
You can install anoth video card without turning th onboard video off, you will see the option to use the new video card in the windows display settings, if you do not hook a monitor up to the onboard video it will not use it either.
Posted on Mar 10, 2009
How to turn off on-board video device ?
Go into bios and disable it if you can, if not remve the video card, update the OS and put the card back.
Sep 07, 2015 | Computers & Internet
How do i disable the video on board in p4 motherboard
It depends on the BIOS manufacturer but usually you need to enter in to the BIOS settings to change the video settings.
Oct 28, 2011 | ASUS P5GL-MX Motherboard
I put the card on my PC and connect de monitor to the card (VGA). when system boot, the speaker of the board sounds beep, like everything is good, but no video. And yet the card plugging in the board, but...
Hello friend,
Please i think you card is not acceptable by the system, or have you checked another card on the system to see if it displays the same thing. And when you remove the card the system boots normal without any error. So check on the card make a change on it.
Jul 04, 2011 | Creative Labs 3D Blaster 4 Titanium 4200...
How do i find in my mother board graphic card installed
Follow your motherboard manual's instructions to enter the setup CMOS. look for the option that lists the on-board functions, such as video or graphic card. If your motherboard has the video card on-board, there will be an option to enable it or disable it. Set this option to "enable" if it isn't already. If your motherboard does not have on-board video, it must have a video card installed in that slot. In either case, if you have a monitor display when you turn on the computer, your video card IS enabled.
Oct 06, 2010 | ASUS P5GD2 Deluxe Motherboard
Would like to find a bios manual to turn off the on board video so i can install a new video card
hi there,
NO need to turn off your on board video (VGA on Board), just plug your Video card in, plug your vga cable to it then install the driver.
dm
Aug 10, 2010 | Computers & Internet
My biostar g31 -m7 te motherboard does not boot when i try to add a msi rx800 pcie video card,,sometimes i get a overclock fail message after i remove the card and reboot,,,how do i get this card to work...
Turn the computer off.
Remove the PCI-E video-card.
Boot the computer.
Press DEL to "enter BIOS setup".
Disable the "onboard video" adapter,
or set the highest video-priority to be the PCI-E slot.
Save settings, but do not "exit" from BIOS setup.
Install the PCI-E video-card.
Disconnect the video-cable from the onboard VGA-port,
and connect the video-cable to the new video-card.
Turn the computer on, and the video-output through the new video-card should be displayed on your monitor.
Nov 05, 2009 | Biostar G31-M7 TE Motherboard
Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Jan 17, 2009 | Dell 828FI 15" CRT Monitor
Pb not seeing my new video card
The 9600 video card, I am fairly sure, has a connection on the card itself for power. Have you maybe fogotten to connect the power supply to the video card? If not , try reseating the video card.  A third possibality.. Some MB, if they have on board video, require you to turn off the "on board video" in order for it to use (see) the New PCI video card. Hope this helps.
Dec 06, 2008 | Gateway GT5220 PC Desktop
Video card
When you turn on the computer, it should say something like Press F2 to access setup/bios. Do that; there should be a setting to turn off the onboard video card. Varies by board, so I can't tell you exactly, but if you post your motherboard information, might be able to get you specifics.
May 05, 2008 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Disabled onboard video in bios in hopes that new video card would kick in, now how do i turn it back on so i can see again
with a second monitor and win xp, you can run both videos. just plug in card and plug in second monitor and xp will take care of the rest...you will see special messages first boot
May 28, 2007 | AOpen MX4LS (91.88Q10.001) Motherboard
ASUS P4P800-MX Motherboard Logo
211 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
