Question about Sanyo DP42746 42 in. Plasma Television
I have a sylvania 42 plasma tv and I would like to know which digital tv tuner I would use for this tv
  • Sanyo Master
  • 5,568 Answers
You didn't include any model number so we can't do much for you.
Check your your owner's manual to see if your set is equipped with an ATSC tuner. If it is, you need no external tuner. If it isn't, any will do but I like the Zinwell ZAT-970.
Posted on Mar 20, 2009
42" sylvania 6842thg plasma displays digital television and then shuts off after about 1 minute.
Evening It is not energy saving that is bothering you,is it? Try SET-UP and see if you can change it there. Good luck Kolbrun
Aug 24, 2012 | Sylvania 6842THG 42 in. Plasma HDTV
How do i hook regular cable to Maxent MX-42EPM20 42 in. EDTV Plasma Television
Your Maxent MX-42EPM20 is not a TV (Television) it is a Plasma panel. The difference being your Panel does not a TV Tuner (no Coax jack or electronics relating to a tuner) Below is the spec sheet that shows this
http://reviews.cnet.com/flat-panel-tvs/maxent-mx-42epm20/4507-6482_7-32139310.html?tag=mncol;subnav
You can use a cable box or a cheap Digital TV receiver. You can buy them at walmart, You need one with A/V out puts such as Component. Here is a link to one. This will give you a tuner.
http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
Feb 18, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
I was just given a 6842PE sylvania tv. when i plugged it in and connected the satellite the screen is very fuzzy and has a black 1 in line straight down the middle of the screen. i can see the outline of...
the 1inch black line is either a buffer board gone bad or the ribbon cable from the plasma screen to the buffer board, the snowy picture could be many things, including y-sus, xsus or tuner boards
Mar 27, 2011 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Where do i plug my cable cord into on my 42 inch sylavania
Hello - The fact is that your TV, as a HDTV ready device, is really a display monitor that does not contain any TV tuner. There is no place to attach your coax TV connector.
To view TV on the unit you would have to either subscribe to cable or satellite TV service or buy yourself an external TV tuner such as listed HERE (I'm not recommending this tuner just showing the kind of device you would need.)
Regards and thank you for using Fix Ya.
Mikeywaf
Mar 22, 2011 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Is my ILO 42" "EDTV" plasma ready for just a regular antenna?
No, it doesn't have a digital tuner. If you want to watch digital channels you will have to acquire a digital set-top box and connect it to the tv thru the av inputs.
Jan 16, 2010 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Where is the cable antenna hole?
There is none, you need to use a cable or satellite box with this TV. It's a monitor with no tuner.
Oct 11, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
How to hook up cable without using a cable box
this is a monitor plasma tv and it will need some type of tuner to bring the cable channels down to the audio/video jacks or the composite video jacks(blue/red/green) you can use a cable ready vcr to input the video in tv jacks and hook up the cable in to your vcr rf input.
Sep 01, 2009 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Hi i have a 42'' 42'' sylvania pla model 6842 pf m and have a bli
if stand-by voltages are good, you probably have bad inverter board. could be one or two depending on unit
Mar 09, 2009 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Using my universal remote on my Sylvania 6842 TV??
send me an email and I will tell you the code. I am in seattle and have some extra remotes.
Mar 15, 2008 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Delay in built in tuner is unacceptable
Because it has a built in tuner there will be a delay since the tuner has to process all bands for each channel for analog and digital signal.
Dec 20, 2006 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Sanyo DP42746 42 in. Plasma Television Logo
101 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
