Question about Nortel Norstar 16-Line PBX Speakerphone
Correct time displayed on phone screen
Nortel Networks M3904 phone displays incorrect time. How do you correct this?
  • yewsful
    yewsful May 11, 2010
    This is done through the maintenance terminal. Do you have access to the maintenance terminal?
  • formulacoop May 11, 2010
    The M3904 phone works on the bigger pbx's like the Option 11, 51, 61, 81. To change the time on the pbx, which will change the time on the phone, you will have to log into system programming from a console interface connected to the pbx. Do you have access to this console interface and do you know the login and password?
SOURCE: Changing the time on a Nortel networks phone
Feature **time (type out time on the dialpad.)
Posted on Apr 17, 2008
cnavarro
  • 2460 Answers
SOURCE: TIME DISPLAY
So the real answer is: Do you people buy these phones and forget to attend the training class, or does your dealer expect you to call evertime something happens?
The time display on a 76xx phone comes from the phone system. It is adjusted via Caller ID, or via system programming.
Carl
Posted on Aug 23, 2008
SOURCE: How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Posted on Mar 12, 2009
flst rider
SOURCE: nortel phone m3904 won't forward to an outside line
The DN may not be configured to allow forwarding to an outside line for security reasons. I think the default is 4 digits. You will need to talk to whomever programs your switch and ask them to allow this feature.
Posted on Jan 20, 2010
consultel1
  • 860 Answers
SOURCE: how to change the time one hour ahead
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press soft key "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press soft key "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press soft key "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press soft key "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press soft key "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Posted on Mar 19, 2010
How do I set up a voice mail with a Nortel M3904?
This is dependent on you being able to access your voicemail mailbox (a mailbox has been setup for you by the administrator and you know the codes to login to your mailbox). Go to your voicemail which should be:
  1. press the message key.
  2. Enter your mailbox number, then press #
  3. Enter your password, then press #. (if you don't know this then you will have to contact the administrator for the telephone system)
When logged into this:
  1. press 82.
  2. Press 1 for external greeting, 2 for internal greeting, 3 for temporary greeting, or 9 for Personal Verification (spoken name)
  3. Press 5 to record then wait for tone.
  4. Press # to end recording
  5. Press 2 to listen to the greeting
  6. Press 76 then 5 to delete the greeting and re-record it.
  7. Press 4 to return to your messages.
Nov 24, 2014 | Nortel Networks Meridian M3904 Corded...
Display is blank
Phones I work on have a ribbon cable going from display window to main body, sometimes get knocked around and ribbon cable dislodges. Just have to reconnect cable, inside the phone.
Apr 22, 2014 | Nortel Networks T7100 Corded Phone
How do I change the time on my BT T7208 telephone (Nortel Network).
1. Press Feature x x 8463 (x x TIME) you should have Password displayed on your telephone.
2. Enter 22742 (BASIC) or 23646 (ADMIN) you now should have Hour on your display.
3. Now press Change and enter the correct hours using the key pad
4. Press NEXT and you should have Minutes displayed on your telephone, now press CHANGE and enter the correct Minutes.
5. Press NEXT and you should have Year displayed on your telephone, now press CHANGE and enter the correct Year.
6. Press NEXT and you should have Month displayed on your telephone, now press CHANGE and enter the correct Month.
7. Press NEXT and you should have Day displayed on your telephone, now press CHANGE and enter the correct Day.
8. Now you will have ---End of List--- displayed on your screen, you can now press Rls or handset down button to come out of programming.
Feb 28, 2011 | Nortel Business Series Terminal T7208 -...
How do i program ip 2033 on nortel system
when you plug it in, and the Nortel logo appears on the screen, swipe the three buttons that are under the display, with your finger, and that will get you into programming.
you will select following
Manual DHCP config? yes
Partial? yes
enter the IP address of your system
for port #: enter: 7000
retries: enter 5
for the rest of the programming select "0" till the end
Aug 23, 2010 | Nortel Networks IP 2033 Audio Conference
How to change the time one hour ahead
7.- Select AM or PM
10.- Enter minutes
13.- Enter year
16.- Enter month
19.- Enter day
Mar 18, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Nortel phone m3904 won't forward to an outside line
Nov 10, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Step 1
Mar 11, 2009 | Lands Phones
Time on Nortel PBX is correct but some phones show incorrect time
Unplug all but one phone (at a time that you wont have incoming calls), Do either Featue **ADMIN (**26464) set the time, then plug in the remaining phones
Mar 04, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Time display
Check the network time settings. If the phone time is "Set by network" maybe the network time servers are messed up. Set the time on the phone manually and see if the problem is fixed. If the phone is already set manually see if setting it to Set by network will force it to keep correct time, but the internal clock should be more stable than that. You may need to get a replacement if these tricks don't work.
Nov 19, 2007 | Motorola Mobility RAZR V3
Nortel Norstar 16-Line PBX Speakerphone Logo
722 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
