Question about Maytag PYE2300AY Electric Dryer
Loud noise the dyer is making a loud notice, but is drying
  • CCook04 Mar 14, 2009
    Maytag electric dryer works but makes loud noise like the drum isn't on the track. This happened after drying a comforter that probably was too big for it. Oops! how do I check this? and if off track how do I put back on?
    New Friend:
  • 102 Answers
Could be that one of the bearings that the tub rolls on is wearing out and needs to be replaced or the belt pulley running to the motor is worn and needs to be replaced. Hope this helps
Posted on Mar 10, 2009
My dyer is working it's just making a really horrible loud noise what could it be?
possibly worn out Support wheels.
Worn out Idler off the motor
Jun 03, 2015 | Dryers
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Ge profile is making loud squikei noise how to fix it
is it a scraping squeak or a squealing noise?
Jun 09, 2012 | GE Dryers
My dyer is makes a loud, rattling sound.
did you find what caused the blower fan to break in the first place?I suspect the casing around the fan may not be clearing and something is in the fan again. or the keepers to keep it on the motor shaft are loose. The rollers for the drum and belt may be faulty. these are all of the parts that move so it has to be one or more of them.
Mar 01, 2012 | Amana NED4500VQ Dryer
I have a 2005 GMC Sierra Z71 4x4 that recently started making a loud creaking noise in the front end. It is very loud and occurs instantly when turning the steering left or right, and also is noticeable...
You might want to check the ball joint. None of them have grease zerks and can dry out. They will cause a noise when turning or hitting a bump, if really bad. Hope this helps.
Aug 13, 2017 | 2005 GMC Sierra
When operating dryer makes LOUD thumping noise. Is this fixable?
this sounds like rotator wheel(s) are broken. It is some what an easy fix. The drum dyer needs to rotate those wheels. Usually you need two.
Jan 05, 2011 | Asko T741 Dryers
The dyer still works but it makes a loud noise and doesnt produce the same amount of heat as before
LOUD CLUNKING NOISE WHEN THE DRUM TURNS? IF SO, YOUR ROLLER BEARING IS BAD. AS FOR THE LESS HEAT, YOU NEED TO CHECK YOUR VENT, MAKE SURE IT'S CLEARED. IF SO, YOU HAVE BAD COILS
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Frigidaire Dryers
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Maytag PYE2300AY Electric Dryer Logo
107 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
