FixYa.com
Tags:
OCZ Gladiator 3 CPU Heatsink & Fan
CPU Fan Help
By Bouncy - usenet poster
I have an ageing system now which needs updating but until I have sufficient
cash to do it I content myself with minor tweaks and alterations. Which
brings me onto the subject of my CPU Fan - it's way too loud!
At the moment I have an old Taisol sitting atop an Athlon 1800XP. It's
basically the 60mm fan I want to upgrade cos I'm lazy and don't really want
to have to get the whole Mobo out, put a new heat sink on and all that. Can
anyone recommend a replacement fan? The current noise rating on my Taisol is
about 35 db's (I can't remember the exact number but it's not far off this).
Any suggestions much appreciated.
Paul
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
Chandler
Chandler - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On Thu, 8 Jan 2004 19:46:35 -0000, "Paul Baker"
The OCZ Gladiator 3 is very quiet.  I don't have the equipment to
measure the dB's, but it's comparable to the early pentium fans in
noise level.  You can still hear the air moving, but the annoying buzz
that the high RPM fans have isn't there.  The low noise version is
quieter (it's the one I have), but I understand the regular LED lit
version is also very quiet -- if that's your thing.  Keep in mind that
while both of these versions have a skived slid copper base, neither
is meant for overclocking.  Even comes with a small tube of heat sink
compound rather than a thermal pad.
The other alternative is to get a fan funnel type adapter and use a
larger fan at a lower RPM.  It's quieter, but you have to keep in mind
that not all case configurations will accomodate something like this.
It takes up a lot of space, and sometimes the drives or tall
capacitors will get in the way.  The other consideration is that the
larger fan is usually an 8cm case fan, some of which do draw more
current than a CPU fan.  As such, using a molex connector instead of
the motherboard header is a good idea.
If you do decide to replace the HSF, keep a tight grip on the heat
sink when you release the clip.  Many of these heat sinks have very
stiff clips.  If you release it without controlling the motion of the
heatsink, it will roll over to the side where it is still attached.
This may chip the core.   The replacement cost of an 1800XP isn't much
these days, but that doesn't make it any less annoying and swear
worthy if it does.
Thanks,
MCheu
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Chandler
Rating: 0%, 0 votes
On Thu, 8 Jan 2004 19:46:35 -0000 Sat down laughing as it's habit to
keep on crying then "Paul Baker" <paul_bakerNOS @go.com> wrote :
Silent/cheap
I'm using one of these,
http://www.cclcomputers.biz/ac atalog/coolersA370.htm
http://tinyurl.com/3cobu
  MicroFlow2 SPA07B2 (Skt A) Ref: CLR0006
Supports AMD Upto XP3200
Very impressed.Even comes with it's own version of,"Arctic Silver"
thermal paste which means the whole kit costs less than a tube
of,"Real" Arctic silver!
I flatted the base of the HS with wet&Dry 500 paper and then mirror
finished with,"Brasso" metal polish.Then applied a small amount of the
thermal paste to the Raised Athlon core spread thin.
O/C XP1800
Idle temp 38 Deg C ATM
1 Back 80mm case fan blowing out.
Max under load earlier in the year when warmer under 50 Deg C.Well
within spec.
HTH :)
Free Windows/PC help,
http://www.geocities.com/shepp ola/trouble.html
email shepATpartyheld.de
Free songs download,
http://www.soundclick.com/band s/8/nomessiahsmusic.htm
Solution #3
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
Unless you've got a case that's really unfriendly to users, you shouldn't
have to remove the motherboard to replace the cooler.  The following article
is older, but should be very helpful.  -Dave
http://www.tomshardware.com/cp u/20030113/cooler5-39.html
Solution #4
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
here is what i've done a few times:
i've removed the fan and then mounted a small case fan on a bracket.
i position it facing down and about  1/4" or so above the heatsink
i;ve found that it cools better and because it runs at a lower rpm...
it;s quieter...
i'd run a temp check before and after replacing the fan to confirm the
results
Can you Help with these System Cooling problems?
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
System Cooling
relay unit
car fires up but then dies need... Answer This...
System Cooling
Warning light.
Electronic fault indicator... Answer This...
System Cooling
Peoplesoft
There are how many ways for... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
