Question about Maytag Performa PAV2200
Need to install new motor on Maytag PAVT454EWW
Hi
The old motor locked up (at least I think it did...the belt was melted, there was carbon dust all over the floor and nothing happened when you turned on the washer). It is about 11 years old.
I was going to buy a new one, but I found a new motor for just 80 bucks, so I thought, what the heck, I can fix this!
When I took the old motor out, there were a zillion little rubber washers, plastic fittings, etc., that I unfortunately did NOT pay attention to since I thought the new motor would have them. Wrong. I need to use them, but it's now like a puzzle trying to figure out what piece goes where and which go above the frame holding the motor and which go below. I tried my best, but now when I turn on the washer, the motor slides all around -- not good!
I've looked, but I cannot find a schematic that will show me exactly what order all these washers and footings go in that are used to attach the new motor to the frame. Can anyone help me please? thanks!
Aquativa, I need parts of that burnt motor if you dont need it. I'll pay the shipping charges. Let me know. (480)-554-209 seven - Miguel
Posted on Apr 12, 2009
  • 86 Answers
Try going to partselect.com to find the parts they have a picture breakdown of your washer and you can buy the parts right there
Posted on Mar 14, 2009
Im trying to replace a fan on a simplicity freedom f3300 vacum. HOW DOES THE OLD FAN COME OFF? It seems to be pressed on but I dont want to brake anything.
Assuming you have the motor out of the fan housings, check to see if you can move the fan around clockwise/counter-clockwise. If the fan is not moveable, the fan has probably melted to the motor housing. Replacing the motor is recommended as the plastic motor housing under the fan is probably damaged/melted. It could still be fixed but there is a possibility of damaging the housing. If after removing the fan following the directions below be sure to remove/trim any melted plastic away from housing before replacing fan. Not trimming the plastic could result in your new fan melting again to the housing when the machine is turned on. If you have an older model pay careful attention to the carbon brush area, if there are plastic posts holding the carbon brush springs, these are easy to break.
If the fan is movable, remove the nut and washers from fan. Use two large flat head screwdrivers and place them opposite of each other under the bottom lip of the fan between the fan and motor housing. (it might be a little easier if you have an extra pair of hands to hold the motor). With the flat heads in place, push the handles of the flatheads toward the side of the motor where the belt shaft is. If the fan does not pop off rotate the position of the screwdrivers and try again. Pay close attention that the fan washer is installed before replacing your new fan. after installing the new fan, rotate it several times making sure it isn't rubbing anywhere.
If you need any further help feel free to contact me.
Tim
TheVacCenter.com
Mar 02, 2013 | Simplicity Freedom Cord - F3300 -...
I have a maytag washer, toploader which was working fine until recently. Now when it starts rotating, there is a burning smell all in the area. What causes it?
Hi
Your washer uses a belt to transfer the power to the tub from the motor. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer.
Remove the old belt & remove the bolt holding motor. Now remove the motor, remove & replace the plastic isolators with the new ones supplied with the belt on the motor spindles. After re-installing the motor & bolt adjust the new belt.
Please post back for any further assistance.
Daniel
Jul 31, 2010 | Maytag Dependable Clean Top Load Washer,...
Need to get a plastic pulley attached to motor without motor
Hi, Is the plastic pulley on the motor or is it on the belt idler asswmbly? THe model # you have given is for a Whirlpool washer. This model doesn't have a belt. It has a coupler to connect the botor and transmission. Do have a model # for the maytag washer?
Vic
May 20, 2009 | Whirlpool WTW5100SQ
I have a Maytag Atlantis MAVT754EWW machine and there is a black soot like substance being left on the floor under the washer. It smells like rubber - do I need to replace the belt and if so, how do I do...
this black soot like substance is the motor carbon brush dust. i would get the motor brushes replaced and clean off all the dust from the pulleys and also replace the belt as it has been slipping on the dust.
Mar 18, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
How to replace a belt on a Maytag MAV6000 washing machine
hey good for you thats an eazy one .pull the washer out abit and then tip so the top resting on wall behind.be careful dose not slip out from under but ihave done it a hundred times as a repairman.before replacing the belt inspect the motor pulley,its plastic and they do melt.also inspect the pump pulley making sure it turns freely and the spot welds are not broken joinning the pulley to the pump shaft...........other wise just spin the old belt off and spin the new belt on.the belt goes on a total of three pulleys .thats it if you need any other help you can email . God bless ,tom
Jan 08, 2009 | Maytag MAV6200 Top Load Washer
Drum Does not Rotate
the carbon dust that you mention ? on the drivebelt will//may have come from the electric motor carbon brushes especially as you sy machine is 4 yrs old you can diy inspect the brushes by removing the rear panel to access motor unplug the socket from motor then slacken belt and remove belt from pully remove the motor you will see location f brushes x2 opposit each other and normally held in position ont armature of motor by coiled pressure clip like watch spring and brush has wire embedded in it and other end a push on terminal? when these brushes wear down normally the fist indication is fast spin slows then eventually no rotation of drum? over a period of time? SO easy diy to renew brushes if as above worne down /not contacting armature? cost approx £5 here in n/west uk worth investigating and diy saving ££££s $$$$s? and i hope you have good luck hope this helps/inspires you?
Oct 26, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Maytag 2005 washing machine top load model number PAVT454EWW makes a loud grating noise when it seems to be in a agitation cycle, and the motor is running and the belt is working, but the agitator is not...
HI thanks for the question. yes it sounds like the tranny. Maytag has 5 yr warranty on the tranny. have it replaced thanks the appliance doc. please rate my answer.
Oct 07, 2008 | Washing Machines
Maytag PAVT454EWW pump 21002240
Don't worry about it, you can install the new pump with out the plate. It will work just fine. They must of redesigned it. I get them this way all the time, Catriver
Sep 22, 2008 | Maytag Performa PAV2200
Washer motor for maytag machine
NOT THE RIGHT MOTOR!!
You would have been better to order the correct one and wait for it!
Now you put good money into bad!
Call these guys and relax!
BUT,if its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
May 29, 2008 | Maytag Performa PAV2200
New belt
First put the belt around the small pulley, shd be the motor pulley i think. Then ease the belt around the big pulley & gently move clockwise if the pulley is on the left side; anti clockwise if you are inserting on the right side. The belt will fall into place. Actually it is very simple.
Apr 18, 2007 | Maytag SAV4655A Top Load Washer
Washing Machines Logo
378 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
