Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
I forgot my username an password
I forgot myusername and pass word
    Scholar:
  • 135 Answers
Disclaimer: Following information should be used only if its your system and you have forgotten account password. Don't use this information to access a system which is not yours without permission.
Many times we face this problem when we or our friends forget Windows XP password and can't log in Windows. So here I'm posting a few methods / utilities which can be used to recover Windows password:
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2nd Method:
Windows XP and further versions also provide another method to recover forgotten password by using "Reset Disk". If you created a Password Reset Disk in past, you can use that disk to reset the password. To know more about it, please visit following links:
How to create and use a password reset disk for a computer in a domain in Windows XP
How to Log On to Windows XP If You Forget Your Password or Your Password Expires
3rd Method:
If the above mentioned tricks don't work, then try following trick which is actually a loophole in Windows XP Setup and a big security hole:
A. Boot using Windows XP Setup CD and follow the instruction like Accepting EULA, etc.
B. When it asks to repair your existing Windows installation, accept it and press "R" to run the repair.
C. Setup will start repairing your Windows and will start copying files, etc.
D. After a few minutes setup will restart your system and when it restarts don't press any key when it shows "Press any key to continue..." otherwise Setup will start from the beginning. Don't press any key and setup will resume where it left.
E. Now it'll start doing other tasks and will show a small progress bar with a few details in left side.
F. Look carefully at the details and when it shows "Installing devices", press <Shift>+F10 keys in your keyboard.
G. It'll open a Command Prompt window. Now type nusrmgr.cpl and press <Enter>.
H. It'll open the same "User Accounts" window which you see in Control Panel.
I. Now you can remove or reset any account password without any problem.
4th Method:
There are many 3rd party utilities which claim to recover forgotten Windows password:
Windows Geeks Lost Forgotten Password Service:
Windows Geeks have a program that works instantly to remove any lost or forgotten password. With this program you can get back in very quickly:
Emergency Boot CD:
EBCD is a bootable CD, intended for system recovery in the case of software or hardware faults. It is able to create backup copies of normally working system and restore system to saved state. It contains the best system software ever created, properly compiled and configured for the maximum efficient use.
You may download image builder utility which creates image of bootable CD-ROM (.ISO file), plus basic set of system tools. When the image is ready, write it to CD-R or CD-RW, and then everytime you'll need convenient and powerful system tools they'll be just at hand.
It is easy to customize the disk for your needs. You can include to CD any program you like, or remake the structure of CD completely. All you need is to change a few lines in configuration XML files.
Download Link
Offline NT Password & Registry Editor:
This is a utility to reset the password of any user that has a valid (local) account on your NT system. You do not need to know the old password to set a new one. It works offline, that is, you have to shutdown your computer and boot off a floppydisk or CD. It'll detect and offer to unlock locked or disabled out user accounts. It is also an almost fully functional registry editor.
Download Link
Windows XP Login Recovery:
Login Recovery is a service to reveal user names and recover passwords for Windows NT, 2000, XP, 2003 and Vista. As long as you have physical access to the computer, your passwords can be recovered.
Download Link
Ultimate Boot CD (UBCD):
Ultimate Boot CD runs independently of any operating system. It will boot from any Intel-compatible machine, regardless of whether DOS/Windows/Linux/BeOS is installed on the machine. However, you do need an operating system and a ISO-capable CD writer software to create the Ultimate Boot CD from the downloaded ISO image file.
Download Link
5th Method:
If all fails, then simply reinstall Windows and create new accounts. To recover lost data, you can use Data recovery tools available on net but the chances will be very low to get data back.
That's all I can suggest. Thanks for using FixYa and please rate my reply thanks.
Mike.
Posted on Mar 10, 2009
  • 4 Answers
Download hiren's boot CD, and reset the password (assuming its your windows account)
    Guru:
  • 108 Answers
You just need a reset CD, with which, you can empty all your password without log on.
As far as I know, windows password unlocker(http://www.passwordunlocker.com) is capable of reset windows password by creating a reset CD, After you have downloaded Widows password unlocker, it contains a .ISO file, you need to burn the .ISO file onto a blank CD. Well, with this CD, you can reset your password. Besides, this CD is multiple used.
Posted on May 18, 2009
Facebook didn't accept my username it was an error
Click 'Forgotten password' and you will receive a password reset email from Facebook - once you reset your password you will be able to access your account again.
When it comes to entering your username, ensure you are using your whole email address as the username (myusername@facebook.com for example).
Mar 18, 2016 | Facebook Computers & Internet
How do I log on to my account? What information you need? If you want my account number I would like to know who you are? Who is "fixya"
You must never pass on your password. Normally one needs the user name and password. That is it, you're in.
Jan 08, 2015 | Computers & Internet
Forget my username and pass word for face book
Click the "Forgot your password?" link on the Facebook sign-in page. The link works for the username as well as the password.
Aug 20, 2014 | Computers & Internet
I forgot my pass word and want to change it. My daughter put in her security pass word and can't remember it for a wireless-G 2.4 GHz Broadband rouuter.
Hello
You can do a factory reset.
1 unplug all cables to router.
2 Hold down small reset button behind router,use a pen tip to hold this button in for 30 seconds.
3 Reconnect cables,power cable first.
4 Log into router using default password and username.Which should be......
username=admin
password=password or admin
Once loged in you can reset your username and password to what you want.
Oct 13, 2011 | Linksys Wireless-G Broadband Router
I forgot my password for 2go so i can't login
i wasnt given a password by 2go
Jan 27, 2011 | Home
How do I clear my autocomplete in Chrome? I have forgotten to hit Tab between entering my username and my password on one or two sites so when autocomplete kicks in I see two options - one is my username...
In the upper righthand corner of your browser, click on the wrench looking icon (customize and control Google Chrome). Click Options. Click Personal Stuff. Click Passwords. You can now go in and delete the passwords that are causing you the problems. When you go back to the website, you can reenter your passwords the way that you want and Google Chrome will save them correctly.
Jan 01, 2011 | Google Chrome
The problem is i cant remember entering my pass word when setting up my face book account and now i am ask for my pass word.
When you first setup your facebook account, you actually had to setup your Username and Password. In case you forgot your Username or password, you can always click on "I Forgot My Password" and an email will be sent to the email address you used to register on facebook containing both the username and password.
Go ahead, click on "I Forgot My Password" and fillout the form, check your email and try logging on to facebook.
Oct 05, 2010 | Computers & Internet
I just bought it and tried to change the pass word and accidentally locked myself out dont remember username or password
You forgot the BIOS password. Remove the cmos battery.OR You forgot the OS password Reinstall operating System.
Feb 03, 2010 | Office Equipment & Supplies
Keep getting error message re: KDE and 'dcopserver'
I am not 100% sure, but I remember having a similar problem once. The reason is that root stopped owning a couple of ./kde files, so that a user had not correct access to the files.
Open a terminal and type:
myusername@ubuntu:~$ sudo chown myusername:myusername /home/myusername/.*
Password:
Replace "myusername" with your username. The password asked will be root's password (which might be the same as yours.)
Jan 05, 2009 | ASUS Eee 4G Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
390 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
