Question about Kenmore Refrigerators
GO HERE to locate your board.
Spending time to find the bad component is futile without proper testing equipment.
Prices range from $50 to $200 depending on the board in your fridge.
Thanks for using FixYa!!
Posted on Mar 10, 2009
Good afernoon and welcome to fixya
you can unplug the fridge and wait a couple of minutes ( this wont hurt anything) then plug it back in. make sure that everything is working fine such as fridge is operating, then start the hunt for the control panel at the parts house of your choice. good luck with this.
Hi there. There is no reset, nor is there a fuse on the board. That unit is very solid state. When you blow the board, it's blown. You should make sure you have power to the frige first, if so, then you need to replace the entire control board. Probably 60 to 100 bucks depending on your parts house. Sorry, and good luck.
Rob
try to unplug the unit and defrost it.
Jun 16, 2011 | Kenmore Refrigerators
Mar 02, 2010 | Kenmore Refrigerators
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Aug 08, 2008 | Frigidaire FRS26R4A Side by Side...
Nov 30, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Jul 14, 2007 | Kenmore 71812 / 71814 / 71819 Bottom...
48 people viewed this question
I HAVE A KENMORE [REFRIDGE] SIDE BY SIDE,MODEL #253-556-7940B.I HAVE REMOVED FRONT COVER TO WATER AND ICE DISPENSER OFF THE LEFT DOOR OF MY UNIT .I NEED TO REPLACE THE WATER PADDLE IS ROKEN.WHEN I REMOVED THE COVER PLATE THEIR IS A WIRE THAT SUPPLIES POWER TO CIRCUIT BOARDS I NEEDED TO UNPLUG SO I DID .THE UNIT WAS STILL PLUGGED IN AS I WAS REPAIRING THE PADDLE AFTER REINSTALLING EVERYTHING I NOTICED I HAVE NO POWER TO ANY LIGHTS NOR POWER TO ANY OF THE BUTTONS,THEREFORE I HAVE NO ICE OR WATER COMMING OUT ,NONE OF THE CONTROLS ARE WORKING FOR THE FRONT DOOR ACCESORIES ANYMORE.I MIGHT HAVE BLOWN THE CIRCUIT PANEL OR SOMETHING BECAUSE AFTER I REPLUGGED IN THE ELECTRICAL PLUG IN TO GET ACCESS TO REPAIR ,I FOUND THERE IS NO JUICE TO FRONT ANYMORE,COULD I HAVE BLOWN THE CIRCUIT OR SOMETHING INSIDE OF ICE SHUT CONTROL AREA???? IS THERE A RESET OR ANYTHING SIMPLE I CAN DO TO RESTORE THE POWER TO FRONT CONTROL PANEL FOR ICE AND WATER TO WORK AGAIN
I HAVE A KENMORE SIDE BY SIDE REFRIDGE. MODEL#253-556790B,THE PROBLEM IS I NEEDED TO CHANGE OUT THE WATER PADDLE IN THE LEFT DOOR IN DOING SO I REMOVED THE FRONT COVER GIVING ACCESS TO ELECTRONICS AND PADDLE AREA INSIDE WAS A WHITE PLUG IN FOR THE POWER TO THE DOOR BUTTONS AND FUNCTIONS ON ICE AND WATER DISPENSING.I UNPLUGGED [WITH POWER STILL CONNECTED TO WALL OUTLET ON FRIDGERATOR BACKSIDE].WHAT A MISTAKE THIS WAS I SHOULD HAVE UNPLUGGED IT TO DO REPAIR .ANYWAY WHEN I DID REPAIR TO WATER PADDLE [REPLACEMENT] I HAD TO REPLUG IN THE ELECTRIC PLUG TO CIRCUIT BOARDS AND NOW I HAVE NO POWER TO ANY OF THE FRONT OF DOOR UNITS.I AM THINKINK I MOST LIKELY BLEW A CIRCUIT OR PANEL BOARD.IS THIS POSSIBLE ? HOW CAN I CHECK TO BE SHURE WHAT I MAY HAVE BLOWN AND IF IT IS THE BOARD CAN I REPLACE JUST THE ELECTRICAL PIECE I MAY HAVE BLOWN OR DO I NEED TO REPLACE THE WHOLE BOARD?IS THERE A DIODE OR SOMETHING I CAN CHANGE INSTEAD OF THE WHOLE BOARD.HOW MUCH? is there anything i should check and how can i look to see if something is blown or shorted.WHAT WOULD BLOW IF I WERE TO GET A SPARK THREW THE ELECTRICAL CONNECTOR I PLUGGED BACK INTO THE SIDE OF THE CIRCUIT BOARDS IN PADDLE AREA?
