Question about Canon PIXMA MP460 All-In-One InkJet Printer
Computer illiterate needs help on how to scan documents from canon/serial#jcyb25729 pixma mp460 into windows/vista software
  • Canon Master
  • 5,390 Answers
All you need to do is go into Navigator and select photo/document, this will take you to a screen where you can select photo/document etc. Then select resolution (the higher the dpi the better the quality, but slows down scanning). Follow the instructions. When scan is complete a small picture will appear, and a dialogue box asking if you wish to scan again, if you do put a new document on the cover and press scan. If it doesn't look right ignore the picture and rescan. When done exit at the dialogue box. The small pictures can be selected and edited or turned around using the icons. You can save one image at a time just by selecting the image and not the others. If you want to make a PDF, then select the images in the order you want the pages to appear in and save as a PDF.
Posted on Jan 08, 2010
Do I need Ink in my Canon Pixma MP460 3 in 1 printer to scan photographs on to my computer?
If you only scan your photo to your printer no need to used inks for that...just click the scan icon witch located in your pc...thanks
Aug 07, 2011 | Canon PIXMA MP460 All-In-One InkJet...
How do I scan a document?
Do you have the full software installed or just the basic driver from Canon? What OS are you using? http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#DriversAndSoftware has the software and drivers. If you installed the OS driver, you should uninstall that, disconnect the data cable and then install the driver from Canon. The generic OS driver usually only runs the printer.
Place the document face down on the scanner glass or face up if you have an ADF. Check that the all-in-one and the computer have good bi-directional communication. (Direct USB connection (if you are using that), replace cables if the printer works but not the scanner and the Canon software is installed.)
If you are using the Canon software, you need to set up the destinations for the buttons and have the monitoring software running. Thus start scanning from the computer at first. Launch MP Navigator and then click on the type of document you want to scan. Find the resolution and contrast that works for you. Use these in setting the button defaults (see the manual from Canon). Then click Scan.
Alternately, with Windows XP, Vista and Win7, you can scan with software that came with the OS. Paint is available on all of these OS versions (File > Import from camera scanner > from scanner). Vista includes PhotoGallery which works like Paint (this can be downloaded for XP and Win7). Vista and Win7 also can scan with Windows Fax and Scan (New Scan).
When you have the MP Navigator properly set up, you will be able to launch a scan from the printer. Press the Scan button and the software will launch.
I hope this helps.
Mar 04, 2011 | Canon PIXMA MP240 All-In-One InkJet...
I want to scan a document with my MP 180, need the steps to do it with the controlls that are ON the printer please...
For the MP 180, assuming the all-in-one is connected with a good USB cable (and port) that gives full bi-directional data transfer and that the computer has the full software installed, press the Scan button (third button from the left) then Press Black or Color (depending on your document). Then the MP Navigator should open on the computer and then scan into the software.
I hope this helps.
Mar 23, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Won't scan
I had this problem, but I have Windows Vista. Epson finally addressed this problem. If you have Vista - and you cannot scan with the Canon MP460...just go to Epson's website, and go to troubleshooting. There you will find an upgrade that is necessary - it's the 'Service Pack 1'. Download it to your computer...and you will be able to scan immediately.
Jan 27, 2010 | Canon PIXMA MP460 All-In-One InkJet...
How do i scan a picture on a canon MP460 printer ?
hey
place the document in scanner feeder
hen go to control pannel
select the scanner and camera wizard
click on canon scanner
click next and scan the document
Sep 19, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Not getting pc to scan
ok...window vista as long as i am remeber got window photo gallery inside....you can scan you document use this window photo gallery.....or other choice you can use software utilities from HP.(the software came together with printer) if still cannot...you can download latest HP F380 printer driver from hp website......
could be the software together with printer just only for win XP...
Sep 13, 2009 | Canon Pixma MP500 All-In-One InkJet...
I have a PIXMA MP460 Cannon Printer. The printer works and I can also copy but I can not scan documents to my PC. Any suggestions?
Try re-installing it again. You may have not installed the application software for scanning if you did a Custom Install.
Jul 10, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Mp460
i had same prob at first
1. put doc in scanner
2.press scan
3.press cloor or black
4.press scan again
Oct 14, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Canon Pixma MP460 problem...cannot scan
i was told that the printer needs to be directly connected to the imac (not airport) for the scanner to work.
i have the same issue w/ the airport extreme.
May 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
121 people viewed this question
old marine
old marine
