Question about Maytag MSD2756G Side by Side Refrigerator
We have a Maytag Side by Side Refrigerator SS2, Model MSD2757AE which continually has ice build up in the freezer which in turn doesn't allow the refrigerator to cool properly. We have been defrosting manually about every 10 days as repairing services have been too many. Have been told we need a new board but haven't been able to find the part number and cost might be prohibitive. Thanks for any help available.
  • barbeetn Apr 06, 2009
    Thanks for info, a logical answer.
  • tom3665 Apr 13, 2009
    Freezer is cooling down to - 10 on average but Frig side is staying up areound 35 to 40 degrees... Unplugged and defrosting for the second time. What do I need to look at and or repair?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
You have adefrost prpblem you have to get the board just give model#
Posted on Apr 06, 2009
Side by side refrigerator will not cool on refrigerator side plus a build of ice temp control, model # psb2151grw
It sounds like your freezers' evaporator coils are not defrosting normally.At least once a day ,a refrigerator automatically defrosts the coils in the rear of the freezer compartment.In most cases ,the electric heater that is activated by a timer circuit,comes on and melts any ice buildup .If that heater doesn't come on for several days,the ice builds up into a solid block,and it doesnt allow any air to pass thru to the refrigerator side of you box.
Nov 14, 2012 | Maytag Refrigerators
Msd2757ae freezer leaks water
Leaking Refrigerators Just What may Be Happening
I am pretty sure you are having a defrost drain blockage problem, and click here=>
Leaking Refrigerators! Let me know if helpful, Sea Breeze
Feb 23, 2012 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrigerator model number MSD2735GR - Leaks from freezer. Ice build up around condensation drain hole. I have unthawed twice and unclogged ice from the condenate line. Keep having same problem.
I suggest you empty the freezer. Then use a hair dryer to copletely dry the entire inside of the freezer then make sure everything you put back in is dry. I had this same problem and this worked for me. Just had to much humidity in freezer.
Jan 01, 2012 | Maytag MSD2732GR Side by Side Refrigerator
Maytag mzd2665he side by side coils inside freezer have ice build up
The defrost relay may be the problem,it also coud be the defrost heating element,you will have to remove the back panel inside the freezer side and do a continuity check on heating element if that has continuity then element is good,then the relay which is located on the wiring loop to defrost element is probably bad.locate a replacemant part and replace relay and that should solve the ice on the coils.
Jun 20, 2011 | Maytag Refrigerators
Refrigerator side doesn't feel cool but the freezer side is cold for a Maytag refrigerator model # MZD2766GE
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Jul 21, 2010 | Maytag MZD2766GES Side by Side...
Side by side Maytag frig that is warm on top, not bottom
You can turn the thermostat off for now to let the ice thaw out, if a door was left open there might not be anything wrong, but if it freezes up again sounds like you might have a bad defrost heater or defrost limit. Hope this helps
Apr 25, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer not properly defrosting
On the adaptive defrost control board...cut the orange/white wire.
This will put the board into a standard 8 hour defrost cycle.
Mar 10, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer is cold, but refrigerator is warm
Sounds like you have a defrost problem... is there a large build up if frost in the freezer section on the back wall??
Aug 20, 2008 | Maytag Refrigerators
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Right side of refrigerator not cooling; frezzer working great
The coil is the thermostat that controls the damper which allows more or less cold air into the fridge compartment and should be put back as you found it. Very important. The problem is that the freezer is not defrosting, hence the ice build-up on the back wall. Either the defrost timer is faulty or the defrost heater is blown. There are two thermostats behind the freezer panel, one in line with the fan and one in line with the heater and they will be clamped to the pipework. Both these thermostats should be closed when iced up. If the fan is not running, that could be faulty too or its thermostat.
Nov 02, 2007 | Maytag MZD2752G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
503 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
