Question about Samsung PCK5315RX TV
I get double picture like a shadow on screen
The blue allignment line will not adjust but the others will. what do i need. model # pck5315r not sure what i need if it's the sub deflection board or a convergance problem and is it easy to repair. thank you Bill
  • billslifeisg Mar 13, 2009
    thank you for your help it was right on.
  • 111 Answers
Please rate!
First, the STK convergence IC is possibly burned. Usually on the right lower side,accessed from the back, is a module with 3 black stk's on it. If you see the stk's then replace all 3. Not one as the others will blow really soon. Also check to see if green coils are burned,if so replace them. Get parts from matelectronics.com. Good source and inexpensive, about 40 bucks for the parts...Give a good visual and then proceed. be careful! high volts still in there, but don't worry...
Posted on Mar 11, 2009
Colors wont line up and will not manually adjust.Screen is also bowed. Last time this happened I replaced sub deflection board and this cured problem.I just replaced this board again did not fix problem
sounds like the power supply for this portion of the set isn't working this will result in a bowed picture with the colors failing to line up- check that the voltage that is supposed to be there is.
Feb 02, 2011 | Samsung Televison & Video
There is a green line that surrounds things, like a 3d image. the green is out of allignment. Can i order the parts i need?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 22, 2011 | Hitachi 53FDX20B 53" Rear Projection...
I purchased the convergence chips for Samsung PCL5415RX/XAA TV. Do I need to remove the entire sub deflection board to R&R them?
Yes, however I would be surprised if changing the two Ics will repair the set, as that chassis should always have the sub-deflection board replaced since most of the resistors will be stressed. Thats why samsung changed the later chassis's by removing the convergence circuits from the deflection board as its almost 98% certain that the deflection board will need replacement when the ICs fail with those chassis designs unless every component in the convergence circuit is replaced which will cost more than the deflection boards do. But you may get lucky but if the ICs dont cure the problem you will need a new deflection board
Dec 23, 2009 | Televison & Video
Mitsubishi TV Model #WS65903 - Green Shadow Lines on Screen
Something is not right here--The green is adjustable in the TECH menu--did this person adjust or try to adjust in the customer or the TECH menu?
If you confirm actual model number I can tell you how to get into the TECH menu--yes--green will not adjust in customer menu--it determines geometry and is only adjusted in the TECH menu.
Also, this set requires any convergence adjustments to be done in 480 and then in 1080--if only adjusted in one mode the other will still be bad.
Let me know if you know how to adjust in TECH menu or not--with exact model number I can tell you how to get there.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Samsung tv model # HCP4363WX Ghosting
The convergence board that you replaced will not correct the issue that your describing as your model has the convergence amp circuits located on the Deflection board. You would need the deflection board which is available at the following link. It also has a picture of the board which is in your model its the large board on the right with the Flyback and both Convergence ICs on it.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Dec 16, 2009 | Televison & Video
Seeing double
You need to replace the convergance IC's
Sep 03, 2009 | Toshiba 56H80 56" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Televison & Video Logo
138 people viewed this question
Henry  Thomas
Henry Thomas
