If you are just talking about the windshield washer pump/motor that squirts water on the front windshield, there is no separate fuse for that pump. If you are talking about the front windshield wipers themselves then the fuse for that (including the washer pump) is located is the fuse panel inside the vehicle down below and to the left of the steering wheel. Below is a diagram of the fuse layout (first picture) and I marked the 10 amp fuse for the system. As I said if you are talking about the pump/squirter motor there is no separate fuse. Inside the wiper motor itself (located basically on the firewall on the drivers side) is an internal microprocessor as well as an internal relay for that pump. If the processor or the relay is bad, both are internal and the whole wiper motor assy. has to be replaced. It's one complete unit. There is a chance that the pump motor itself could be bad. In the second picture is a breakdown of the washer fluid reservoir. In order to get access at it which is where the washer pump motors are located the right front wheel and splash guard have to be removed. I have marked the 2 washer pump motors which are mounted on the reservoir. I cannot tell you which motor is which but the one for the front has 2 wires at the connector (a black & white wire and a black wire) The rear pump motor has a violet & light green wire and a black wire at its connector. That's how you can tell which one is which. You can test the motor by either pulling it out and applying direct power and ground to it to see if it engauges or while someone is engauging the washer inside the vehicle while you are down there, see if you are geting power at the black and white wire. Check that wire while it is disconnected and using a good separate ground. If you are getting power make sure the black wire is geting a good ground. If all is good (ground & power) than more than likely the pump motor is bad. If you have a power supply problem at the black & white wire than you are looking at most likely a bad wiper motor assy but check for an open power wire from the wiper motor to the pump motor. It's not quite as simple as it used to be. The wiper motor on your vehicle has like a mini computer in it. I'm gonna say the washer pump motor is bad which is the most common. Hope I was able to help and that I didn't get too technical on you but things are not like the old days with separate motors (wiper and washer).
