Question about Whirlpool Duet GHW9150P Front Load Washer
Washer only fills up 1/2 way.
Whirlpool LSL9244EQO
My washer has a small, medium, large and super plus load size selector.  No matter what the setting is it fills about 1/2 full.  The rest of the cycle seems to run correctly.
    President:
  • 1,314 Answers
Sounds like the pressure switch is bad
Posted on Mar 11, 2009
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Washer does not fill with enough water.
The water level is controlled by a pressure switch connected to a long rubber hose that goes inside the tub. If the switch is defective or if the pressure hose is blocked the machine may under-fill.
Check also inlet hose and water pressure from the house.
Mar 28, 2012 | Washing Machines
I have a Whirlpool ZUltimate Care II Washer, Model 3XLSQ7533JQ2. Washer keeps filling in the medium and the super wash level and will not go into the agitation cycle. Works on small load level only.
SInce the washer works ok on the small load size yet overflows on all others the problem is going to be with the water level switch and it should be replaced to remedy that problem.
The part number for that water level switch is W10339229 it could be purchased at your local appliance parts store or online at
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer filled up with water during regular beginning cycle and once fill washer just stopped. I feel like this happened before and it was something that may have gotten stuck in the drain??.....I move...
Hello LazyOne
The motor is locked out until the water level requirement is met. The level selector switch is probabably having issues, try rotating it back and forth between small / medium / large loads. If it starts to fill on larger load sizes, it will be the switch itself. If it doesn't do anything at all, it could be the switch, but most likely it is the level sensor. Both are located in the compartment behind the controls panel.
Sep 10, 2010 | Kenmore Washing Machines
Washing Machine Causes Flooding
call the whirpool repair service! if it's still under guarentee they should repair it free of charge!
Oct 16, 2009 | Washing Machines
Continous water filling
HI, the water level switch is damaged on this unit. you will need to replace this switch. this will fix your level issue.
May 27, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
173 people viewed this question
Dan Webster
Dan Webster
Sal De
