Question about GPS
I have a 2008 Garmin Nuvi 780 with the MSN cable antenna and the lifetime paid service.My problem is the green light on the auto cable plugin lights up but it still does send power to the GPS.I only can use the GPS by connecting it to my computer to charge the battery.It will work perfect for about 1 1/2 hours before the battery runs down.I tried a reset at the plugin with a small wire and a reset of the GPS device by sliding the off switch to left for 10 seconds.I do have some limited electronic skills. Thanks Harry Hitt NDNDRIFTER@gmail.com
  • ndndrifter Mar 10, 2009
    I also did a firmware update that still did not fix the problem.The device worked for 14 months before this problem.
    I tried connecting the GPS to my other vehicles but still have the same problem.
  • 15,935 Answers
The charging jack on the Garmin is a known defect. It is a weak solder joint on the main controller board.
Repair will involve disassembling the unit to re-solder the pins to the board.
If its under warranty - send it in for repairs.
If not - disassembly and re-soldering is your only option.
Thanks for using FixYa
Posted on Mar 10, 2009
    President:
  • 987 Answers
A hard reset is accomplished by pressing the right bottom of the screen and holding g while turning the unit on. After about 4 seconds the Garmin logo comes on, continue pressing the right bottom corner until the “Do you really want to erase all user data? No Yes” appears. Pressing Yes will return the unit to its out-of-box state.
  • 201 Answers
Logic says that if it charges fine in the computer, but not in any car, the auto power cable is the problem - I assume you're not using the cradle. the plugin may be fine, but the cable to the GPS or the connector may still be bad. I'd suggest a new auto power cable.
    Brigadier General:
  • 5,158 Answers
The cigarette lighter power source may be defective... mine usually switches right on when i plug it in tho yours sounds like it is going straight to battery charge mode. after you plug it in... try sliding the power switch on for a second and see if that changes things
Robert
  • 19,396 Answers
That sounds like a defective battery.
You should also test the power output to the GPS charger in your car, and verify that it stays within +or- .5 volts from what is indicated on the GPS charger socket.
  • 6,784 Answers
Change the fuse in the auto cable
  • Michael Masters
    Michael Masters Mar 10, 2009
    the fuse inside the auto cable socket insert is blown. screw the top off the auto cable plug in , and replace the fuse inside.
  • Michael Masters
    the fuse is bad...
    Genius:
  • 1,550 Answers
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
    Brigadier General:
  • 3,614 Answers
HI THERE,
better try to test it with a new batery pack
  • micromaster
    micromaster Mar 10, 2009
    you must try it with a newly battery on the unit. or better contact Garmin for the service
    Top Expert:
  • GPS Master
  • 77,499 Answers
I have a garmin and I would suggest that you register your device at my garmin and use there free tech support, they are really easy to understand and will help u quickly resolve this issue. here is the link, remember u will need to register to use the service, it is free
https://my.garmin.com/mygarmin/customers/myGarminHome.faces
We need to register our garmin nuvi 57 Lm so we can get get our life time updates on maps and there is no directions on how this is to be done.
Go online to Garmin.com and download the "Garmin Home" app.
Install in your computer, fire it up and connect your devise with the proper USB cable and your machine should automatically send you back to Garmin and ask you if you'd like to Register' you device now or later. Pick "Now".
This will allow you all updates and features you paid for.
Oct 09, 2016 | Garmin nuvi 57LM 5" GPS with Built-In...
The garmin turn on them the light turn off and the touch screen does not function. the version is the nuvi 780
Possible bad battery---are you charging with the lighter plug in the vehicle or what? That plug it uses for the lighter will have a fuse inside it in most cases.........
Nov 08, 2012 | Garmin nuvi 780 GPS
Garmin 265wt I want to know if my garmin have a free lifetime traffic incluse
Yes, the nuvi 265WT comes with a lifetime license for US traffic. That doesn't guarantee that you have a station in your area that broadcasts traffic information, and you must use the special power cable (which contains the antenna) for it to receive anything. You won't see anything on the screen unless/until the nuvi recognizes a traffic signal.
Dec 17, 2010 | Garmin 265WT 43 BTTraffic wGarmin Case...
My Garmin nuvi 780 will not turn on. When I turn on, the Garmin logo shows on the screen. However, when "Loading Maps" is displayed, 1-2 seconds later the screen goes blank. This occurs when the unit is...
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Apr 03, 2010 | Garmin nuvi 780 GPS
Hey
they dont give you a home charger with the unit. here is what you should have received
What's in the Box:
  • nüvi 780
  • Preloaded City Navigator® NT for North America
  • MSN Direct receiver with integrated vehicle power cable
  • 3 months free MSN Direct service*
  • Vehicle suction cup mount**
  • Dashboard disc
  • USB cable
  • Quick start manual
the usb cable supplied with the gps will charge your unit using the usb port off your computer also.
i bought a home charger off ebay to save a few dollars but you can buy them off the garmin website HERE just click the accessories tab and scroll the the bottom of the page.
or go HERE for the listings on ebay
Oct 17, 2009 | Garmin nuvi 780 GPS
My GARMIN stop working I plug it to my car socket and it would not come on.
Same, it worked in the morning, then after lunch, it would not come on. Totally dead. I check the cable and it is working. I have a backup cable too so I know it isn't the cable.
May 06, 2009 | Garmin nuvi 780 GPS
Registering
I have been trying to updating my Garmin nuvi 200 with the North America 2008 map and I'm getting a message that says This Garmin is not eligible because a previous map version is not installed....HELP - I leave for Candad tomorrow and of course there closed tonite. Can you help?
Jun 15, 2008 | Garmin nuvi 200W GPS Receiver
Opening the Garmin Nuvi 350
Hi:
It can be easyto open. There is a couple of nuts behind the antenna, you have to remove them, then you need to remove the antenna, in order to do this you need to find a pin in the base of the antenna, and slide it to the center, and this free your antenna, then you can reach a couple a nuts located under the antenna, remove them and then you will be free to open your nuvi. I did this cause my power button was broken, I resolded and now is working pretty fine. the picture is my nuvi 350 opened.b67f991.jpg
Oct 30, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
23 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
