Question about Dishwashers
Whirlpool Quiet Partner 1 not cleaning on the top rack
I removed the top cleaning head and removed any debris that may have obstructed the flow. It is still not cleaning on top.
  • 108 Answers
Turn it on and let it run for a little while. Open the door and check to see how much water is actually in the bottom. Depending on which model you have, you should have at least the entire floor covered in about 1" of water. If it looks like you can fit a couple quarts of hot water in there, do so, and see if that helps.
If it does, you probably need a water inlet valve, because you aren't getting enough water in the machine fast enough. Check the valve knob under the sink first and make sure that it is open just to rule that out.
If you do have enough water in the bottom, you might want to call a repairman... or start taking it apart and checking for anything that is blocking water flow.
Posted on Mar 10, 2009
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
Apr 24, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool dishwasher quiet partner 1 top arm is not rotating?
I have same problem, anybody know how to fix this?
Feb 10, 2010 | Whirlpool Dishwashers
I have a whirlpool quiet partner II dishwasher. There is a gritty residue on the dishes in the top rack and on some of the silverware. Any suggestions on how to fix this?
Jan 16, 2010 | Whirlpool Dishwashers
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Whirlpool quiet partner II top rack sprayer doesnt work
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 | Dishwashers
Not cleaning dishes especiialy the ones on top rack. Found some broken glass pieces in bottom. No obstructions in line leading up to top washer. It looks like the pump is not pumping enough water pressure...
If you remove the filter in the sump area underneath the lower dish rack (removing the screws to do so) you may find debris blocking/jaming the impeller area. Be very careful of almist invisible broken glass. Inspect the impeller to make sure it is properly in place and not damaged.
Confirm that the spray arms are not pluged.
If problems continue and the impeller is in good shape, the pump motor may be failing. Please get back to me if problems persist but also include the Make and Model number whe nyou do.
Mar 29, 2009 | Dishwashers
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it:
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwashers Logo
482 people viewed this question
Top Dishwashers Experts
