Question about Dell Inspiron 1525 Notebook
No display is comming
When start the computer theres no display
I had the same problem with an HP Pavilion laptop. In my case it was very simple. Everytime you close up a laptop the screen pushes down on a little button that signals the monitor to turn off. If that button gets jammed it will stay off. All I did was push the button up and down a few times and the screen started to work. If that fails do a search on the internet about your problem. I did and there is a fix posted. There is some part that can be replaced If I recall correctly that fixes the problem and supposedly it is not hard to replace.
Posted on Mar 10, 2009
Lenovo z570 black screen at start up
You may like to check the Lenovo (IBM) page on screen diagnostics:
http://mobilesupport.lenovo.com/gb/en/products/laptops-and-netbooks/ideapad-z-series-laptops/ideapad-z570/documents/HT062642?tabName=Solutions
I searched the internet on "no display on laptop" which gave some informative results, but as only you know all the details of what is wrong only you can decide what is relevant.
I found the following interesting, but there are many more:
1. http://www.windowsbbs.com/pc-hardware/42349-laptop-no-display-screen.html
2. https://answers.yahoo.com/question/index;_ylt=AwrBTzGx1V5To3QA5QxLBQx.;_ylu=X3oDMTE0ZXVrMTVyBHNlYwNzcgRwb3MDMQRjb2xvA2JmMQR2dGlkA1FJVUswMV85Mg--?qid=20090409183121AACuZ46
3. http://www.ehow.com/way_5272815_laptop-display-screen-problems.html (on the right hand side of this article there are links toother articles about laptop screen problems)
Does your computer beep more than usual when you turn it on ? Tis may be a sign that components are loose or have come out, or there is some fault which must be looked up.
To find out if it's your screen, connect an external monitor via the VGA port on the side of your computer Press the function button to select the external screen, or both, and if you get a display on the external monitor it's your screen or components associated with it, for example the 'inverter' or the CCFL if your computer has one. It may be that the display has become disconnected from the computer (there is often a ribbon connector). It may even be the graphics/video hardware on your mainboard. If it's the screen, you can replace it: detailed instructions for a similar model are here
http://www.insidemylaptop.com/how-to-replace-lcd-screen-on-lenovo-ideapad-z575-laptop/
If this is case you need to disassemble your computer and find out what is wrong with screen. The manuals for your computer can be found here
But you rea;;y need to find out what is wrong before you can even attempt to fix it. If you are not able/knowledgable enough to dissemble your computer, DON'T.
28.April.2014
Apr 28, 2014 | Lenovo IdeaPad Z570 15.6 inch Laptop -...
No display on monitor
There are a number of possible reasons after checking what you have so far. Have you checked that the video card has not been disturbed inside the computer?.
Try starting your computer in safe mode, see link below. Just in case you have a driver problem.
http://windows.microsoft.com/en-gb/windows/start-computer-safe-mode#start-computer-safe-mode=windows-7
Dec 21, 2013 | Sony 15 Inch Tft Lcd Color Computer...
Monitor - Display problems
There may be a power supply failure in your monitor
May 30, 2013 | ViewSonic VA712 17" LCD Monitor
No video signal vga laptop to tv
Make sure you have the TV's input set to PC or Computer to receive the signal from the VGA.
Make sure the connections are snug on the computer and on the tv.
Reboot the computer and see if it automatically starts the display on the tv. If not, there are a sequence of keys that you can press to toggle the display between the tv and the computer.
Normally to toggle the display you will have to Press and Hold the FN function key located at the bottom left portion of your keyboard and then hit the corresponding key (F1 thru F12) that toggles the display. The correct F1 thru F12 key to hit will have the CRT/LCD on it or it might have the icon of a display.
Apr 22, 2012 | Toshiba Computers & Internet
Driver vga ms 6526
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrative tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers
if you don't have a disk with the drivers you have to download them
http://download.cnet.com/vga-zip/3000-2108_4-159201.html
http://download.cnet.com/1t2xw26-exe/3000-2122_4-120557.html
http://download.cnet.com/acjxw01-exe/3000-2108_4-120624.html
Oct 16, 2011 | Computers & Internet
I have no graphics drivers
if your computer came with a motherboard disc the sound and video drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers also Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or you might need to download one
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers this would apply to the sound video and game controllers
http://download.cnet.com/%7Bvalue=http://www.download.com/jetway-motherboard-driver/3000-2098_4-163033.html
hope this helps
Jul 11, 2011 | Intel D915GVWB Motherboard
Hi, I have a K8V-MX motherboard where everything was up and running. I decided to and AGP video card into the board for some extra memory but now I cannot get the computer to work. I turn the PC on...
the video card might not be compatible with your computer you might have to remove the video card from your computer or
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly. there are a number of graphics card drivers for download
http://download.cnet.com/%7Bvalue=http://www.download.com/ati-catalyst-display-driver/3000-2108_4-10608736.html This release for all Radeon family products updates the AMD display driver to the latest version. This unified driver has been further enhanced to provide the highest level of power, performance, and reliability.
hope this helps
Apr 13, 2011 | ASUS K8V-MX Motherboard
VIG DRIVER
Here is the link to the VGA driver, and the other drivers for your motherboard. Click HERE. You didn't include your operating system with you question so the one listed on the link is for XP 32bit. If you have a different system just select it there from the drop down menu.
Apr 11, 2011 | Gigabyte GV R575SL-1GI - graphics adapter...
My computer cones up with a message that says the computer dosn't support the graphics
or
http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance. ... and save profiles for Direct3D and OpenGL applications ...
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html
Hope this helps
Mar 19, 2011 | Asrock Motherboard K7S41GX for AMD...
Dell Inspiron 1525 Notebook Logo
Alun Cox
