Question about HP LaserJet 2420 Printer
We have an HP Laserjet 2420 PCL 5e - it prints perfectly on regular paper but will not print envelopes. We have to manually feed the envelopes on the tray but it only prints gibberish. I have rebooted the printer, the computer and disconnected and reconnected everything. The printer is a direct connect to the PC are trying to print from but it is networked via the pc it is connected to currently. Help!
  • 34 Answers
This is not a printer problem. You have a computer problem. In ALL cases, the printer is told what to do from the computer, it does not report TO the computer.
Posted on Mar 12, 2009
HP Laserjet 2420 unable to print multiple envelopes automatically. Will only print 1 envelope at a time
Its not a envelop printer, its just option only,mechanism built for between ranges of GSM, we cannot put bunch of covers in feeder for print, our monitoring is must.
Oct 07, 2011 | HP LaserJet 2420 Printer
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
HP Laser Jet P2035 is not printing the "from address" on envelops and even the "to address" is not being printed on the right spot. The envelope size, tray and feed mechanism are...
The easy way to diagnose this is to put a regular piece of paper in and print the envelope on that to see where it is actually printing. This is likely a wrong envelop size selected in your software not a problem with the printer. It is only reproducing what it is told to. Also make sure that the paper options in the print driver reflect the correct settings for size of paper.
Mar 17, 2011 | HP LaserJet 1320 Printer
My hp 2420 pcl 5e STOP PRINTING SUDDENLY. & showing me (FUSER ERROR) TELL ME WHAT CAN I DO TO SOLVE THIS PROBLEM I TURN IT OFF AND BACK ON 3 TIMES BUT PROBLEM IS STILL THE SAME.
Hi
Problem either fuser faulty or dc controller card faulty first check for faulty fuser & after then dc controller fuse of fuser.
Thanks
Sep 25, 2010 | HP LaserJet 2420 Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
HP LaserJet 2420 Printing trouble
I think that Odyssey user is right it maybe that the print driver is not compatible with the program you are using goto hp.com or hp.co.uk and download the PCL 5e driver
Hope this helps you
Thanks J
Jan 03, 2008 | HP LaserJet 2420 Printer
HP LaserJet 2420 Printer Logo
201 people viewed this question
Seeker5211
Seeker5211
