Question about HP Color Laserjet 3550 Printer
Paper jams lexmark x3550
The paper shifts slightly to the right and gets stuck then it doesn't feed through. The printer keeps going like it's printing, but it isn't moving the paper through.
    Scholar:
  • 82 Answers
You need to visually inspect the rollers. I suspect that there is a small piece of paper jamming the paper path. Check where it is jamming, and inspect.
Posted on Mar 10, 2009
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Removing paper jam from lexmark x3550
Use a strong light to examine the entire paper path. You may find one or more tiny bits stuck in a tiny space. This may be a result of feeding old or thin paper in previously
Jan 26, 2013 | Lexmark X3550 All-In-One Printer
Whwen I feed my paper in my printer it pulls to the right
take a look inside the printer there are a few small rubber wheels (where paper comes out)
most likely you have a small piece of paper jammed and blocking the left wheel from pulling the paper. they are very delicate so be gentle with them. the issue may also be caused from the back set of wheels where the paper feeds into the printer.
I have a straight piece if clear plastic thet is approx same size as sheet of paper and this is what I use to clear paper jams. The best way to prevent this from happening again is to remove paper when not using and cover printer with a small towel. I have found p-clips and all sorts of junk in clinets printers.
Jul 10, 2009 | Lexmark X3550 All-In-One Printer
X5150 printer turned; no paper in printer; paper feeder continues
Unplug the printer and then open the front and look at the Rear right side and you should see a small ce6913f.jpg
Tab If it is bent then gently with a pencil or pen push it back and try printing if it still gives you problems then contact Lexmark and if you still have a warranty they will replace it if not then you will have to get a new one.
Best suggestion for a new printer that is almost the same is the Lexmark X3550 printer.
Apr 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 04, 2009 | Lexmark JetPrinter Z605 Color InkJet...
Paper not feeding
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Aug 26, 2008 | Lexmark X3550 All-In-One Printer
Lexmark z1300
Aug 19, 2008 | Lexmark Z1300 InkJet Photo Printer
Lexmark paper stuck
Good luck....
Jul 01, 2008 | Lexmark X2470 All-In-One InkJet Printer
LEXMARK PRINTER DOES NOT WORK JAMS PAPER
Nov 29, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
229 people viewed this question
Seeker5211
Seeker5211
