Question about Garden
Karcher k2.36 unable to insert water presser cabe into gun, retaining clip won,t come out
  • paulsable123 Apr 05, 2009
    I’m unable to attach the high pressure hose to the spray gun. Audible click is heard but, high pressure hose is not properly connected, water leaks.
3 Suggested Answers
firesnake09
  • 2923 Answers
SOURCE: Have 5.0 karcher, and it
Make sure that the lance is not blocked and the control valve is ON. Oil coming out of air filter,too much oil in engine,or oil too light should be 30wt, air filter dirty, over speed of engine,these are the only things that can cause this problem.
Hope it helps and have a great day!
Posted on Jul 01, 2009
wmpcs
  • 100 Answers
SOURCE: Karcher Model K 2.40, water is leaking from the
You are going to have to purchase a new trigger gun, they don't offer any parts for replacement on the inside of this trigger gun. See this link to purchase a new one.
Posted on Nov 09, 2010
Connect hose to gun
there is a pin in the bottom of the gun. Take that out with a flat headed screw driver. Then push the hose end up into the gun and then push the clip back in to secure it.
May 12, 2012 | Karcher Garden
KARCHER PRESSURE WESHER
Is this a Singer hand-held, battery operated sewer? Jimmy
Apr 07, 2012 | Sewing Machines
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
Why dose my Karcher K2.35 keep blowing the gun hose off?
There is a good chance you are missing the black plastic clip that holds the hose into the trigger gun. If you look at where the hose goes into the gun there should be a flat slot where a black plastic clip would slide in and keep the hose into the trigger gun.
Oct 24, 2010 | Karcher 2500 PSI Pressure Washer
How do u attatch the hose to the water pressure
There is a black plastic clip on the trigger gun where the hose goes it, just pop the clip out and the hose should come off.
Oct 13, 2010 | Karcher PSI Electric Pressure Washer
Karcher Model K 2.40, water is leaking from the gun at yellow trigger.
Oct 08, 2010 | Karcher FactoryReconditioned K240R 1400...
I HAVE A G30500HR PRESSER WASHER AND ACCIDENTLEY
Hey mate,
You should definately be able to get one of these at your local Karcher dealer, Ive worked at a karcher dealer here in australia and you can get any part you want for them...
Brad:)
Jan 02, 2010 | Karcher G3025OH Pressure Washer
Unable to connect high pressure hose to gun base on Karcher 3.99M
I am presuming when you insert the wand that you are also twisting it into place?
The click usually occurs when the wand is twisted and it locks. Simply pushing it in without twisting will cause water to flow big time as it's not sealed.
If you are doing all correct then the seal is damaged and should be returned for a warranty claim
Jul 21, 2009 | Karcher Garden
Leaking water
The o-ring and the plastic insert is broken. They may not have a part replacement, may have to get a new gun. Take the gun apart and you'll see the problem.
Jun 18, 2009 | Karcher K2.26 Electric Power Washer
High pressure hose. How do you get if off the karcher k 3.99
there is a small clip on the triger where the hose attaches to is, pull clip out pull hose off
Jun 16, 2009 | Karcher K 5.85 M Electric Pressure Washer
Garden Logo
326 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
