Question about Zebra QL 220 Plus™ Thermal Printer
Hi There I've a zebra QL220 plus printer, the printer is unable to obatin an IP address, the configuration file config.lbl is copied to the printer succesfully but the IP info on the printer remains blank
How do you reset this printer to manufacture setting.. I keep getting a error communication with printer. My email address is christopher.wilder@stalexius.net
Posted on May 29, 2009
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Zebra 110Xi III plus I configure my IP, Subnet, and Gateway and save however when I go back to check to make sure I have them correct these configuration will are not in the list of configs anymore to...
change the IP to estactic, and make your changes.
on the printserver is a small withe button, press for 3 secounds, He going to print a network configuration, check that.
Aug 26, 2010 | Zebra 110Xi III Plus Thermal Printer
What is the defult ip address for the zebra tlp2844?
When received or when a reset is performed, the default IP address is: 10.3.4.102. The best way to confirm this is to force the printing of a configuration label. Look at the configuration label that is printed. That will contain the "current" IP assigned to the printer. You can download the manuals for this from the Zebra web site using the model number to get to the printer specific page. Choose the download tab.
Dan
May 25, 2010 | Zebra TLP 2844-Z Thermal Label Printer
How do I configure a Zebrazm4 Plus printer for a
Press the setup button. press next until you get to media type, change from non-continious to continious using the upper config buttons. press setup and next to save permanent. Also you can download Z4Mplus user manual from zebra.com.
May 14, 2010 | Zebra Z4Mplus Label Printer
How do i find the IP address on a Zebra Z4MPlus?
If you can not see it in the LCD menu on the front panel, you can find it by printing the IP info on a label. There is a reset button near the Ethernet jack that will let you reset the print server settings or allow you to print a config label. Load up some media, power the printer on. Once the printer is fully booted, use a paper clip or the like to press the button once. A label will print that details the IP settings. Once you have the IP settings, you can log into the printers web interface by typing the IP address in your browsers URL bar. Do get a copy of the manual.
Jan 19, 2010 | Zebra Z4Mplus Label Printer
No ip info on menu
There is a tiny button on the print server back plane that you can press with a paper clip. This will print out a label with your IP address information. Get the IP address (hope that the printer is set for DHCP) and enter this into a web browser. This will take you to a web interface that will let you make configuration changes to the print server and printer. If the printer is set to static IP, change the IP address of your PC to be in the same subnet as the printer and then fire up the browser.
The user name for the printer is ADMIN and the password is 1234 by default. You can also download ZebraNet Bridge from Zebra's web site. This application will find your printer on the network and let you install fonts, upgrade firmware, change settings, etc.
Jan 19, 2010 | Zebra Z4M Printer
How to check the MAC address of Zebra 105SL Printer
go to the configuration on the printer. Scroll through until you reach the network settings. You can display or print the results, which will show the MAC address. Also, if you have a PC on the same network, and you know the IP of the printer, you can look at your ARP tables and find the MAC associated with the IP. ARP -a at the dos prompt
Jun 23, 2009 | Zebra 105SL Thermal Label Printer
Config page
there is no CONFIG page but there is a setup sheet that will print on how the printer is setup. when the unit is on press & hold the Button till it BLINKS 1 time only. Here is the button sequences. 9a182e0.jpg
Feb 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Unable to reach the device for a statics IP address fro this Zebra TLP 2844-Z printer
I work for zebra. you should user zebra net bridge, its the current network tool and the best to use
Aug 01, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Zebra QL 220 Plus™ Thermal Printer Logo
924 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
