Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune dryer making load noise seems unbalanced
Inside the dryer it looks like there might be some belt residue. Black flakes almost looks like asphalt roof shingle pieces.
How do you service the belt and how do you access it.
model MDE3000AYW
style # 47876516
serial # 13243154uz
  • Maytag Master
  • 3,361 Answers
Sounds more like the dryer drum seal is deteriorating.
If the dryer tumbles the belt is intact.
To access the belt.
Open the door.
Remove 4 screws on right and left side of the door opening.
Raise the door on the hinge side and remove it.
Pull the front panel forward and remove it.
From there you can see what to do next.
Posted on Mar 10, 2009
Maytag neptune dryer has noise inside of drum what is it
it may be the motor , debris stuck in blower wheel or bad rollers . stat be removing the belt and turn the unit on if makes noise you have a faulty motor if there's not noise replace the belt and cleanout the blower wheel .good luck APPLIANCES R EN
Feb 23, 2013 | Maytag Dryers
My maytag neptune washer has black residue on the seal. I have tried everything & nothing seems to take it off. I am now concerned that it is mold. Has anyone experienced this same problem?
Hi just read your posting.The black residue is most likely mould.I have seen it on a few front loaders.Have you tried the product called Mould off ?It helps on some machines.Worse case you might have to replace the door seal.Please reply for further help.Looking forward to your reply.
Jun 24, 2012 | Maytag Neptune MAH6500A Front Load Washer
I have a neptune dryer. It is making a rhythmic
I normally only comment on Electrical Dryers, but you problem sounds like something that is common to all dryers.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, You will probably have to remove the top of the machine first, then remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Oct 15, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer smells like burning rubber or plastic...
The drum belt could be rubbing on something inside. Does the dryer make a squeeking noise? Se if there are small rubber particles on the bottom, this will indicate a deteriating belt.
May 08, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes noise like a bird chirpping.
You'll need to access inside the cabinet and oil the tires and belt pulley. Hope this helps!
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
1999 maytag intellidry gas dryer
The groaning sound seems as if the belt is broaken and the motor is trying to spin a little too fast because it doesn't have a load on it. Take a look to see if the belt is broken and if so, you can purchase a replacement belt at Lowes for approximately $7.00.
Mar 15, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
300 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
