Question about Acer Aspire 5610-4648 Notebook
Shuts self off during start up
When starting computer it will display some thing about checking disc.  shows  code FAT32 and D 230.8324.  then shows 16% done and shuts down
    Problem Solver:
  • 5 Answers
Simple... start to boot your system and press the F8 key to bring up windows boot options screen. select the option disable reboot on system error. then reboot machine and all is good. and let it run check disk... the command prompt syntax for the command is chkdsk c:/f <enter> and it will scan you harddrive and fix any errors. that should stop the rebooting if you disable reboot on system error using the F8 start up option...
later.
cyberburn666@yahoo.com
for question
Posted on Mar 10, 2009
    President:
  • 2,653 Answers
Sounds like there could be a major problem with the hard drive.
Have you got an XP or Vista cd? NOT a restore cd.
  • RescueTechLA
    RescueTechLA Mar 10, 2009
    If you're going to try TheAcerKing's suggestion change the chkdsk /f to chkdsk /r
    That will run a more through check on the hard drive.
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
Stuck safe mode
You should be able to select a menu during start up using F keys,
one will be for bios, but another for windows I think F9 or F5.
Or in safe mode use troubleshooter.
Jan 28, 2014 | Dell Inspiron 530 Desktop Computer
My lap top shut down and would not restart. I called the company and they said I needed to reinstall programs. They sent me two discs, but I cand get them to load.
Step 1:
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 15, 2013 | Dell inspiron 14r-n4110 laptop intel
What is the f7 fault code
I have the double wall ovens. The lower oven read door lock & flashed F7. Check to make sure the lock is not sticking out a bit, it is on the left side of the oven. I'm not sure if this is what the f7 fault code is, but it worked for me :)
Nov 24, 2010 | Fisher and Paykel AeroTech Double OD302...
Dryer problem: clothes are in the dryer, door is shut, on "normal" setting, pressed the start button and it only beeps, does not start.
Is it showing an error code or is there no display? One thing you can do is unplug the unit for one minute and then plug it back in this will reset it and if it is just a glitch it will be gone and things will be OK again. I hope this works for you if not write back with the error code if there is one showing on the display.
Oct 13, 2010 | Kenmore Elite HE4 Electric Dryer
I TRY TO TURN ON THE TV. i GET A FLASHING GREEN,
This symptom seems unusal as there is, what I assume to be, a self check system that monitors conditions and progress of the start up cycle. If there is an abnormal condition recognized during start up, after a short amount of time there should be a malfunction indicated by the LEDs on the front of the set.
Perhaps the self check system is not able to function. If you haven't tried yet, unplug the TV for a few minutes and try it again to see if a reboot of the controls will help. Other than contacting Sony customer service or a local authorized service company, this is the extent of my knowledge about what to try.
There is a error code check that can be displayed, but only if the lamp will come on. To display the error codes, start with the TV off. Using the remote, in sequence press: DISPLAY, 5, VOLUME - (down), POWER. Codes will then be displayed on the screen when the display comes on. To clear the displayed malfunctions, press 8, then press ENTER. To exit the error check mode, turn the TV off by pressing POWER.
Nov 20, 2009 | Sony KDS-R50XBR1 50" HDTV
Displays 104 when it is 65 control is whacky'is it sensor or thermostat, or what
Try this test for codes
Electronic Automatic Temperature Control Module Self-Test
  • The EATC module self-test will not detect concerns associated with data link messages like engine coolant temperature or vehicle speed signals. A diagnostic tool must be used to retrieve these concerns.
  • The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4°-32°C (40-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false in-car temperature sensor DTCs will be displayed.
  • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • To enter the self-test, press the OFF and FLOOR buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer going around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs appear during the self-test, follow the diagnostics procedure given under ACTION for each DTC given.
  • If a condition exists but no DTCs appear during the self-test, GO to Symptom Chart Condition: The EATC System Is Inoperative, Intermittent or Improper Operation.
  • To exit self-test and retain all intermittent DTCs, push the blue (cooler) button. The control will exit self-test, retain all intermittent diagnostic trouble codes and then turn OFF (display blank).
  • To exit the self-test and clear all DTCs, press the DEFROST button. The vacuum fluorescent display window will show 888 and all function symbols for one second. Then, the EATC control assembly will turn OFF (display blank) and all DTCs will be cleared.
  • Always exit the self-test before powering the system down (system turned OFF).
  • Intermittent DTCs will be deleted after 80 ignition switch ON cycles after the intermittent condition occurs.
Jul 30, 2009 | 2002 Mercury Grand Marquis
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Acer Aspire 5610-4648 Notebook Logo
119 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
