Question about Frigidaire Washing Machines
Frigidaire Affinity model # LTF7000ES0 86 error code
Frigidaire Affinity model # LTF7000ES0 front load washer turns on for a second and then door lock light turns off. Holding Start and Cancel button for five seconds shows E68 code.
  • 1525 Answers
SOURCE: Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Posted on Jan 14, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: door open error on frigidaire affinity atf6700 washer
hello, it sounds like you have a bad door latch that needs to be replaced if you need a web sight on were to order one let me know and i'll find the part for you.
Posted on Mar 29, 2009
erickg
  • 116 Answers
SOURCE: The washer door wont shut or lock on my frigidaire affinity
in the rubber seal around door to washer tub ensure there is nothing inbetween rubber.
Posted on Apr 21, 2009
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
Jahn27
  • 1554 Answers
SOURCE: Hi I have a frigidaire affinity washer
The warning sign "Err" indicates that an error has been detected. Check the machine for error codes such as E47 (the control board detects the door PTC circuit (door lock and switch assembly) is open in spin) or E48 (the control board detects the door PTC circuit (door lock and switch assembly) is close),by waking the machine by pressing any button. Wait for 5 seconds then press and hold the Start and Pause/Cancel buttons simultaneously and as long as the buttons are held, the failure code will appear in the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Proceed with replacing the door lock and switch assembly (part #131763202) if error code E47 or E48 is confirmed to address the problem. Post back any error code shown other than E47 or E48 for further advice.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly into position in the front panel and secure it with the securing screws. Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop to complete the repair.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need further advice regarding the issue stated herein.
Posted on Feb 22, 2011
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Replacing lock and latch on my frigidaire affinity washer
Error code 41 is about the door not latching. Appliancepartspros.com has the parts you need. Just enter your model #.
Jul 06, 2014 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire front load washer. When I start a new load it starts with a couple of seconds of water then stops. Does not go into a wash mode, the timer shows it's going thru the cycles but
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Oct 08, 2012 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire affinity wont start
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity washer doesn't start
Try holding the 'options' & 'select' buttons together till the door lock button comes on. This is the child lock function. You can do it again for the lock to come off. Hold down for over 3 seconds
Please reply or rate.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
223 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
