Question about GE Spacemaker JVM1640SJ Microwave Oven
I need to find an incancent 40w 120v bulb for microwave
I need to find an incancent 40w 120v bulb for under my ge spacesaver microwave.
  • 10,865 Answers
This is a common item. Take the bulb to a home depot and they will match it for you or direct you to a local source.
please mark my answer as a fixya!
Posted on Mar 10, 2009
Product is GE Microwave (Spacesaver-type) JNM1731DM1BB. New surface light bulbs installed. Unable to turn them off or change from bright to dim
Bottom lights are controlled through relays on the main control board which is mounted on the back of the touch pads (control panel).You can check and see if wires are touching each other on the board but my guess is the board is defective and needs replaced.
Apr 02, 2015 | GE Microwave Ovens
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm1790wk convection/microwave oven exterior light bulb burned out...I can't read volts and watts on the original bulb and don't find the information in the manual, what do I buy to replace it?
The cooktop light is 120V, 40W max., part number WB08X10051.
That's all covered on page 27 of your owner's manual here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven or part numbers here.
To replace the inside light, you'd need to remove the oven from the wall, and take off the outer cover.
Jul 08, 2011 | GE JVM1790 Convection / Microwave Oven
Need to replace both might lights under microwave.
Remove the screw from the lens cover and open lens. Turn light bulb counter clockwise and remove. Repeat this on other side. The bulbs or 40W appliance bulbs. Take the old one with you to hardware store to match it up. Reverse your steps to put new ones in.
Jun 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
What type of replacement quartz bulbs for the under counter lights?
could be 10watt or 20 watt i for under counter lighting. If too high could burn out low voltage transformer assuming its low voltage....12 volt...
Apr 08, 2010 | GE JVM2070 Microwave Oven
CAN'T GET BULB ACCESS DOOR OFF TO REPLACE UNDERNEATH BULBS
Hello there:
first you need to remove the screws from the back of the microwave that hold on the casing and there might be some on the bottom too. then remove the outer casing
the bulb is under the casing towards the front right corner as you are looking at the front of the microwave
Sep 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Nov 19, 2008 | GE JVM2050 Microwave Oven
Light bulbs
fan may have a lot of vibration. or the MAGNETRON is kicking back a jolt. or your slamming the door too hard.
May 12, 2008 | GE JVM1660 Microwave Oven
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
179 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
