Back to:
Tags:
Gainward GeForce4 Powerpack! Pro/600 TV Graphic Card
Mouse Getting Dozzzzzy
By Powe33 - usenet poster
When I start my system, my mouse responds accurately and quickly. After
several hours use, it seems to 'overshoot' and generally behave in a jerky
fashion. I've tried two different mice(?), both MS optical types. Both
display the same behaviour. Does this mean it's my new video card (Gainward
Geforce4 Pro/600-8X), or a setup issue?
Steve
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
paulrmc
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
No sign of ctfmon (or any other ***mon). Thanks for the help, though.
Steve
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Mouse Getting Dozzzzzy:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Jimmy NY
Rating: 0%, 0 votes
Last time I had sluggish mouse performance, it was caused by ctfmon, some
monitoring app that was running constantly in the background and made
desktop performance slow to a crawl... check your running processes and see
if ctfmon is there. In my case it was installed together with Office...
uninstalling it with office installer didn't make it go away so I had to
manually remove it with msconfig.
/Icarus
Thank You!
Solution #3
Not Rated (0)
LiZzIe
Rating: 0%, 0 votes
Bitstring <bo6kk4$18jfn@ID-173606.news.uni-berlin.de wonderful person Steve Almond < <snip
Does logging off and the logging back on again clear the problem? if so,
then pounds to pennies it is some sort of memory leak, or some left-over
process thread tying things up.
GSV Three Minds in a Can
Outgoing Msgs are Turing Tested,and indistinguishable from human typing.
Thank You!
Solution #4
Not Rated (0)
Riddle
Rating: 0%, 0 votes
Dan,
Thanks for the ideas. I've been running some fairly intensive investment
programmes. Maybe these are soaking up the memory and not releasing it. I've
just built/upgraded this PC with the following:
Windows XP Pro
512MB PC3200
Maxtor 120GB SATA hard drive (almost empty)
XP 2500+ CPU
When I run backtests in my investment software (Amibroker), the programme
shows 156,000 K memory usage and 99% CPU. When the backtest completes the
memory usage remains at ~150,000 K.
Thing is, I used this programme often before my major rebuild without the
mouse problems!
I'll try and dig out an old mouse and see the effect.
Steve
Thank You!
Solution #5
Not Rated (0)
jessie25
Rating: 0%, 0 votes
Quite a few things could be causing this. If it's only optical mice (mouses)
have you tried using a standard mouse (ps2 or usb) to see what happens after
a few hours? I doubt it would be a graphics issue unless your experiencing
other "graphics" problems, which could then point to a graphics card getting
hotter.
Somehow I think the key is in the fact it only happens after a while. The
more the computer is on the more the swap file and the RAM are getting
clogged up, and maybe something somewhere (perhaps a background program) are
slowing down the mouse handler routines. Maybe try closing down any other
software you've got running.
It could be one of many system probs, but I don't suspect graphics. However
I'd need more info on your system setup (OS, Ram, Hard drive (and how much
free space), cpu, what programs you have that start automatically on reboot
etc...) before I could begin to narrow it down properly.
I will have a rethink and let you know if i come across anything. in the
meantime someone else might already know and have solved this dilemma!!
Cheers
Dan
Thank You!
Solution #6
Not Rated (0)
Melissa
Rating: 0%, 0 votes
's not your video card as such. might well be a driver issue though.
Thank You!
Can you Help with these Graphics Cards problems?
Graphics Cards
The software I am trying to run require direct x 9 and I...
Graphics Cards
I think my graphics card isnt working as good as it should...
Graphics Cards
windows vista ultimate, nec model nec versa S32001
Graphics Cards
Hello, Within Premiere Pro CS3 the footage (SD AND HD) is...
Graphics Cards
I lost disk driver car
Loading problems.
Repair Service
Find Graphics Card Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
