Question about HP DeskJet 690c InkJet Printer
HP 690c does not recognize the cartridge
4 times I have my black cartridge re-filled with succes.
But now after the next re-filling he does not like my cartridge anymore.
The yellow lamp blinks like there is no cartridge, but there is one.
And he makes a strange noise. The contacts are clean.Is there something like a memory in the printer or cartridge, so he remembers it as the same cartridge again?
    Scholar:
  • 82 Answers
Yes, some printers do, but I do not think that this one does. The sound worries me, like maybe the cartridge is not installed properly? I would try to take out all carts, power down and disconnect the printer, wait about 5 minutes, then reconnect and reinstall the carts. Where did you get it refilled? That is what I do for a living, refilling and remanufacturing ink and toner carts....
Posted on Mar 10, 2009
Trying to use a re-filled ink cartridge HPf4280
I seem to recall that these cartridges are chipped and you need to get a chip resetter. Look on the base to see if a small circuit board is present. If so then you have to get it reset or buy a new cartridge.
Please rate my help++++Thanks for using FIXYA
May 18, 2010 | HP LaserJet 4200 Printer
Tip
Refilling 5610 cartridges saves Big Bucks!
For those who have not yet tried to refill their own cartridges, you are really missing the boat on big savings.
Remember, printer companies make very little money from their hardware sale... they make TONES of money from their repeat cartridge sales.
That is why they want the empty ones back... they say "to protect the environment and recycle". I don't doubt that but they are really after recycling the perfectly good cartridge and your money while protecting the environment falls at a somewhat lower priority. You will note that the cartridges are not all that large (ink volume) wonder why that is :-) ???
Although the cartridge may be used up, it is good for many, many, many more reloads if properly maintained. I have successfully refilled my black cartridge eight times and the color five times and both are still going strong and have perfect printing quality!
You can purchase ink refill kits from eBay... try a search for "inkjet refill kit for HP". You will probably find several kits available but I got mine from the eBay store owned by Distribution-Online. I have no connection with this reseller other than I use their products and the prices seemed fair. They include detailed instructions so getting started is easy (you need an electric drill, a small drill bit and some scotch tape). Last check, the black ink was about $9 and the color set was $16.
Hints for the HP5610:
1. Refilling the cartridges will not get rid of the low ink message. If you see this, simply press the "ok" button to erase it.
2. You will need to watch your print quality to tell when they need to be refilled. (I.E. faded blacks or wrong colors)
3. Refill your cartridges immediately if you see one is empty. Not doing so may cause it to dry out internally which is a cartridge killer.
4. When filling the cartridges, fill them slowely so the ink is absorbed by the internal "sponges". Overfilling is possible (go slow) but does no damage. You will soon get a feel as to what colors are used up the most. Black goes quickly followed by Cyan with Yellow and Magenta after that.
5. After you fill, clean the underside of the cartridge ( print head that contacts the paper) with high quality alcohol each time you fill, blow it dry.
6. After you fill, clean the connection points on the back of the cartridge (copper contacts) with high quality alcohol each time you fill, blow dry.
Each time I refill, I smile and say to HP (and all the other print cartridge manuactures), I am just doing it... "to protect the environment and recycle"
Good luck and give it a try! -Dan
on Jul 21, 2009 | HP Officejet 5610 All-In-One InkJet...
Had black ink cartridge filled, but now the
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | HP Photosmart C7250 All-In-One Thermal...
How I can reset my canon mp270,lamp B is lighting all the time. I have filled black ink and know my printer dont recognizes cartridge. My computer shows that it is empty.
Nov 14, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Update caused re-fill cartridge not to work
erase all hp software and re-boot with the printer unplugged and the plug the print in and let windows recognize the printer and stay away from new updates you don't need them if the printer works fine an update wont make it better HP updates are insane and politically wrong. GOOD LUCK
Sep 21, 2009 | Office Equipment & Supplies
Printer cartridge refill problem
When a cartridge is filled with non-standard ink, the printer will stop recognizing the cartridge.
Jul 31, 2009 | Office Equipment & Supplies
No paper light ligted even after paper is loaded
Flashing resume light also can mean:
1. cartridge is missing or an incorrect print cartridge is installed
2. cartridge is out of ink
3. dirty cartridge contacts
4. paper jammed
Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
Apr 25, 2009 | HP DeskJet 690c InkJet Printer
Hp f4288 all in one black cartridge( N0.818) refilling method
when i fill this cartidge after finishing the cartidge is not printing why?
Dec 03, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet 690C
actually all printer design by ink its automatic clean up... by head of ink wipe up.
if u encounter in printing for you ink printer
- make sure your cartridge has an ink black/colored
- make sure you u use your printer every month so that it wont be frozen..
- just wipe the head with clean soft cotton with water.
Oct 31, 2007 | HP DeskJet 690c InkJet Printer
HP DeskJet 690c InkJet Printer Logo
102 people viewed this question
Seeker5211
Seeker5211
