Question about Kenmore 62622 Electric Dryer
I have a Kenmore elcetric dryer #64622 I bought in 03, it has been working fine until I had it running, took one article out then it wouldn't start back up. The light inside still works, but the dryer will not start.
  • 2 more comments
  • vickicgma Mar 10, 2009
    I haven't had any problems before, could it be something other than the door latch?
    Okay you said the problem could be the door latch, could it be something else, I haven't had any problems with this dryer before.
    I just want to know what else it could be the problem, in case it isn't the door. I am a disabled female and need to try to resolve this on my own by looking at all the possible problems, I did not mean to offend you.
    If it is a fuse, will the light still work? The light comes on when the door is opened but when I push the button or close the door it goes off.
  • 2,984 Answers
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
You can pick up the fuse really cheap at a Sears parts store. It takes less than an hour to fix. But if you cannot do it yourself, see if you can get someone to do it for you...not worth the cost of the Sears guys coming out and doing it.
Posted on Mar 10, 2009
    Genius:
  • 1,550 Answers
You mentioned light works inside the dryer
So next thing you need to check is the thermal fuse. If the thermal fuseis open the dryer will not start. If the thermal fuse is open, be sureto check the venting for restrictions. The thermal fuse is a safetydevice that prevents the dryer from starting if it senses anoverheating condition.
Other possibilities; door switch, timer, motoror wiring harness problems.I have a Kenmore elcetric - image41910img-or.jpg
    Genius:
  • 1,913 Answers
Check your dryer motor working properly
  • 547 Answers
Blown motor please change the motor thank you for useing fixya please rate me
  • 163 Answers
You may want to check your door switch.push it in and let off of it and see if it clicks.if the finger that goes to switch is not their then you will need new door switch.also if the door switch is good take back off dryer after you unplug it and you will see a fuse on the blower housing it is white with black stripe down center.two wires to it.you can test it by putting the two wires together and wrap with electrical tape plug dryer in and see if it starts.
  • mike cooksey Mar 10, 2009
    light will work but the dryer wont.you will need to pull dryer out to get to fuse.
    some dryers also have a cut off switch if the belt breaks.so check belt also.
  • Kenmore Master
  • 19,396 Answers
If the dryer stopped working after you opened the door in the middle of a cycle, then the problem is usually a defective door latch that must be replaced.
  • 3 more comments
  • Ginko
    Ginko Mar 10, 2009
    Sure it can be something different , also faulty element, faulty fan, thermal fuse and bad control board can cause the same, but you told me that the problem started after you opened the door in middle of a cycle, that can jam the door lock.
  • Ginko
    Ginko Mar 10, 2009
    Well you refused my solution, now I am not sure you will be able to read further comments of mine.
  • Ginko
    Ginko Mar 10, 2009
    Also cut power for ten minutes, if the problem is a jammed control board this can reset the fault.
  • Ginko
    Ginko Mar 10, 2009
    If it is the door latch, that costs less than $10, it should be tested with a multimeter, part here.
  • Ginko
    Ginko Mar 10, 2009
    The thermal fuse is not the main fuse, when the thermal fuse blows on a dryer it breaks power to the heating circuit.
    See more here: http://www.davesrepair.com/DIYhelp/DIYth...">Your Dryer's Thermal Fuse
    http://www.partselect.com/repair.aspx%3F...">Free Dryer Repair Guide - Replace your dryer's thermal fuse
    Also heating element , fan and control board can cause same conditions. However many kenmore will keep working normally, but not heating if the problem is the fan or heating element.
    Here a general troubleshooting page that explains possible causes for your same conditions:
    It doesn't work at all
    I quote:
    If your dryer doesn't work at all, it could be because of problems with:
    Power from the house
    Door switch
    Thermal fuse
    Wiring
    Check
    to see whether there's power getting to the dryer. Is it plugged in? If
    you plug something else into the outlet, does it work? If not, check
    for a blown fuse or tripped circuit breaker.
    Door switch
    If
    the door switch or the door-switch actuator is defective, the dryer
    won't work and you need to replace the failed component. The switch is
    inside the dryer main housing near the door frame. Sometimes you need
    to raise or open the top or front of the dryer to reach the switch.
    Thermal fuse
My Kenmore elite gas dryer buzzes and does not turn on. It has done this in the past, but then a few minutes later would start. (Almost like it was overheated). It has done this occasionally since we...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2011 | Kenmore Dryers
Dryer has push buttons wont come on is getting elcetricity to it
heatman101
Aug 07, 2011 | Kenmore Elite 45986 Front Load Washer
My kenmore 400 electric dryer was working fine. i bought about a month ago. Up until last night. when it would turn it make a short grinding noise then a big THUNK. And i noticed the room was hotter than...
heatman101
Mar 23, 2011 | Kenmore 400 6942 Dryer
I have a 2002 27" kenmore elite gas dryer that runs great except you have to hold down the start button. I took it all apart and cleaned it. The motor looked fine. I think it might be the start button.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 08, 2010 | Kenmore Dryers
I have a Kenmore Elite Gas dryer 2002. Everything works on it except you have to hold the start button down on it. It turns fine, Fires up and heats but let off the start button and it stops. I took it...
heatman101
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Kenmore 62622 Electric Dryer Logo
22 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
