Question about HP Pavilion dv6000z Notebook
I spilled little coke on my lapi sony lf v30, but some of keys are not workg might be 4 keys... how can i skolve this
    President:
  • 2,653 Answers
You'll have to remove the keyboard from the laptop, pull off some keys, and clean the board with a q-tip with a tiny tiny bit of warm distilled water or 99% alcohol or you can purchase some electronics cleaner solution from Radioshack.
DO NOT USE plain old water or soap or anything else.
Pay close attention to how the keys are attached to the white plastic clips, it's not rocket science and there are no special tricks to getting them back on except to use common sense.
If the above doesn't work you can always just purchase a replacement keyboard from ebay for relatively cheap.
Hope this helps.
Best of luck!
RescueTechLA
Posted on Mar 10, 2009
Coke spilled in the keyboard of my laptop and the keys are sticking together now. How do I get the coke out and make my keys stop sticking??
Accidents like this happen, not to worry too much about it.
Method 1: use a damp cloth, (ensure it is not dripping) and clean it multiple times.
Method 2: if you can remove the keyboard (refer to the manual / website support.hp.com for the procedure) and use a damp cloth to clean it and use a vacum cleaner to dry it.
Dec 05, 2010 | HP Computers & Internet
Spilled coke on my keyboard, how do we clean it
Hi
Thank you for your query
Best thing would be to get a damp cloth and simply wipe over the keyboard when the laptop is switched off, this will remove the stickyness.
Please ensure when wiping that no water travels into the keyboard which may cause you problems
Mar 08, 2010 | Toshiba NB205-N210 Netbook
Optical l.e.d. is out
Things do not go better with Coke at least not in this case. You may have done some damage to some circuitry on top of the stickiness on the button. Unfortunately it may need to be evaluated in a computer shop as it's impossible to do anything from here.
Sep 05, 2017 | A4tech WOP-35PU Optical Mouse
My son has spilt coke on the laptop 1 key not working O
If you spill drinks on a keyboard, something is bound to break, and apparantly only the O key did... The only way to fix it is to get a new keyboard, I'm sorry. I hope this helps, Yannick.
Jun 09, 2009 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Cleaned coke off keyboard, not disconnected, wiped over all keys on left side of keyboard. Now nothing works on keyboard at all. How to reset?
Try disconnecting it once and connecting again after restarting...the same thing happened once and disconnecting worked..otherwise just restart and checck the cable is connected properly..
May 27, 2009 | EzKey EZ-8000 Smart Office Keyboard
I spilled a coke on my desk and my key pad got wet I immediately dried it off and put it upside down,but its been a little off by inserting spaces where they don,t belong(I just read this and it,s better...
Coke is sticky when dried, if you can, disconnedt the keyboard and pull the keys off, a flat blade screwdriver should work and wipe everything down.
Or buy a new keyboard for about 10 bucks
Apr 23, 2009 | Computers & Internet
Spilled coke on my laptop, now keys aren't working correctly.
thank you for choosing Fixya.com
i strongly advice you that don't use your laptop as of now.
the reason why keyboard are malfunctioning is the subtance of coke are go inside your unit and if you will still use it it may caused you a much problem.
you need to look a technician and open your laptop to take or dry any subtances come inside your laptop.
Hopefully you will consider my suggestion.
please don't forget to rate our answers properly.
Feb 22, 2009 | ASUS 90-A4C1K1000 Keyboard
Spilled coke on the touchpad and keyboard of Acer Aspire 5920
Not so sure on the touch pad, but the keyboard is easy to remove. Make sure the laptop is switched off first.
There are a series of little clips holding the keyboard on. Look along the top above the F keys you will see 3 or 4 little clips, push each of them in and up (away from the keyboard) using something thin and blunt so as not to cause any damage.
There will also be some little clips each side of the keyboard, these do not push in, you need to manoeuvre the keyboard past these.
Lift the keyboard from the top as it slots into some grooves at the bottom. There will be a ribbon cable connecting it to your laptop, this is easily undone and the keyboard is off.
Jan 25, 2009 | Acer Aspire 5920-6727 Notebook
Sharp calculator
Don't know what model of Sharp you have but most sharps you can take keyboard apart and clean the rubber keypad magnets and the mylar circuit with warm water. let dry and reinstall. Check to see if Coke did not get in other parts. Do not use anything strong such as thinner. Rubbing alschol is good because it evaporates. Good luck
Jan 11, 2008 | Office Equipment & Supplies
HP Pavilion dv6000z Notebook Logo
79 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
