Question about Hobart A200 Stand Mixer
My A200 mixer is very old and the lubricants need to be changed.
I need a diagram of the motor so we can be sure to put correct lubricant in the right place.  I work for a very small public school in Maine and we do not have any money in the budget for a service call.  I think I can do it just as long as I have the correct info.  What kind of lubricants does it take?  Where do I put them?  I would greatly appreciate any help as I am the lunch lady!  LOL Thanks!
  • 10,865 Answers
Http://www.hobartfood.com.au/products.asp?CID=60 go to this page and you will have all the info you need. good luck with it. please rate my answer as a fixya! Get back if i can be of additional assistance . take care.
Posted on Mar 10, 2009
How much/what grease do I put in the planetary system of a Hobart A200?
contact the hobart manufacturer for recommended lubricants to use
Jan 05, 2017 | Hobart Food Mixers
Hobart A200 won't start
If the gearing is all free to move and you replaced the motor capacitor that only leaves the motor. If you can remove the motor and test it "out of the gearing" that would confirm it. You have wired the capacitor correctly and used the correct one? Just asking! Are you sure the gearing isn't jammed up?
May 13, 2014 | Hobart A200 Stand Mixer
How to open the Kenwood Chef A700 and service it?
brendan@rmbs.co.nz, hi there guys, I want to lubricate my Kenwood A700 and would really appreciate your assistance as in what I must open and what type of lubricant would be suitable.
Jan 11, 2010 | Kenwood Food Mixers
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
Aug 27, 2009 | Hobart A200 Stand Mixer
I have oil coming from the front of a hobart a200 mixer,What to look for? and what kind of oil?
If you have oil leaking from the attachment hub, the transmission grease has liquified. The transmission will need to be opened so the old lubricant can be removed, by scooping it out. There aren't any seals in the attachment hub, just two torrington needle bearings. The helical gears thrust the pinion gear onto a thrust bearing in the hub to create a seal. The hub has a return hole in it's casting for excess lube to return internally. It's possible the return hole is restricted. On the other hand, if the machine has been filled with oil, it will probably leak like a siv.
The new lube should be 35 OZ of mobil XPH 222,
Hobart part number is 103881-47 for 32OZ.
Aug 04, 2009 | Hobart A200 Stand Mixer
Kitchenaid K5-A mixer ''growling''
Hi . Chevron FM ALC EP-2 grease is what you need for the lubricant. This has a Mineral Oil base, allowing for it to, at some time, drip into whatever it is that you mix without concern for your health. From what I can, tell this is the only thing that needs to be done. Clean out as much of the old grease as possible.
Goto www.mendingshed.com and download for free a Kitchenaid Service Manual that will cover your mixer.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 16, 2009 | KitchenAid K5AWH Stand Mixer
Still need type of lubricant and diagram as to where to put it.
You will need a food quality grease. Contact a local restaurant supply store and ask them to assist you. Perhaps they will do so for the good will....a pix in the local paper....etc. good luck.
Mar 10, 2009 | Hobart A200 Stand Mixer
Type of lubricant for bowl lift
Go to an auto parts place and buy some Lubriplate grease and use this on the assembly.
Aug 02, 2008 | Hobart A200 Stand Mixer
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Feb 02, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
122 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
