Question about Durabrand Audio Players & Recorders
I am looking for an AC Adaptor (DC 4.5V 600mA or greater with PLUS center polarity)
  • 303 Answers
SOURCE: AC/DC ADAPTOR
click on hyperlink:
buy replacement ac power charger adapter DURBRAND MODEL # APX001A
Posted on May 31, 2009
  • 102 Answers
SOURCE: where i find ac dc adaptor durabrand portable pdv 705
You should go to a local electronics shop with the old adaptor.
They merely need to match: Voltage in Voltage out Current requirements Plug size Plug polarity (center positive or negative) There is nothing "magic" about the original vendors power adapter.
Posted on Oct 06, 2009
  • 5603 Answers
SOURCE: whats the polarity of lexicon
Easy answer: You DON'T set the polarity because this particular device takes a 9 VAC at 2.1 amp adapter. (Not a DC one like so called universal ones)
It sounds like you have one of those universal adapters which probably would not deliver the 2.1 amps required even if the lexicon took DC. Note that stuff might light up, but the unit will not work using a DC adapter..
You had better get an official power supply for this unit as what you have will NOT work, period!
I did a quick search to try and find a link to a supplier, but they are RARE !!! Every one I found would require you changing the plug to match the Lexicon.
You should just order the correct one from Lexicon.
Posted on Feb 05, 2011
cnavarro
  • 2460 Answers
SOURCE: need specs on KX-TG2214 power supply output - ac
6v DC 500 mA center negative It's a PQLV19 http://www.faylist.com/surplus/adapter/panasonic_PQLV19supply6v500ma.htm
Carl
Posted on Apr 21, 2011
  • 8457 Answers
SOURCE: i need a AC ADAPTOR:RFEA213W DC IN ---- 12 V or a
Tries go to Walmart,Target,Radio Shack to buy one yet?Tries websites like Amazon.com,Ebay.com can buy it there too.
Posted on Aug 12, 2011
I need to know the POLARITY of the AC adaptor to provide the correct setting using a universal adapter.
there is no polarity in ac current as ac means alternating current and that means alternating between positive to negative back to positive back to negative and so on
only dc ( direct current ) and the center pin of the plug is designated as the positive pole has polarity, the outer case being the negative
OR Are you asking the voltage of the ac adapter and the voltage of the dc output side of the adapter
Nov 26, 2015 | Office Equipment & Supplies
Power cord
If the voltage is the same, and the current of your replacement adapter is equal to / greater than the original, it should work perfectly fine.
BUT..
The only thing to pay attention to is if it is AC or DC. AC requires nothing more for you to do. DC however, will require that you have the proper polarity: PLUS (+) and MINUS (-) on the mating plug contact points. If you guess at this, you have a 50/50 chance of turning it into "toast". If the socket is unmarked, contact the manufacturer to obtain polarity information BEFORE connecting!
May 16, 2013 | SimpleTech Computers & Internet
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
My External HDD's adapter blow and i want to know if any 12v adapter will make it work?
Be careful, not all 12 Volt adaptors are the same. Some put out AC voltage and others DC. You need a 12 V DC adaptor. The adaptors are polralized, that is one output wire is + 12 V and the other is - 12V.. If you connect it backwards you can blow your hard drive.
If your not sure regarding correct polarity, consult a technician who knows how to use a voltmeter.
Also, the current rating of the replacement adaptor must be equal to or greater than the currenr rating of the original. Example: Old adaptor = 375 Ma. , New adaptor = 750 Ma. This would be OK.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Jan 02, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Where i find ac dc adaptor durabrand portable pdv 705
Oct 06, 2009 | Durabrand PDV-705 Portable DVD Player
AC/DC Adaptor
Greetings jack71471, there are a couple options to obtain a replacement AC adapter for your Durabrand DVD player. One option is to purchase a universal adapter from a store such as Radio Shack. The other option is to buy a dedicated 9 volt AC replacement adapter from a couple sources on eBay. Just do a search for "PDV-709 adapter" and you will find some AC adapters and 12 volt car adapters as well. If you choose the universal replacement option, make sure you bring the player and adapter with you so the salesperson can configure the settings and polarity to match the original adapter. That is unless you are confident enough to set it yourself, in which case you can purchase a universal adapter most anywhere as long as the current rating ( rated in milliamps or "ma") is equal to or greater than the original. Best of luck to you.
Oct 25, 2008 | Durabrand PDV-709
Missing power supply
Output of Factory AC/DC Adaptor: 5.6V DC  600mA
May 03, 2008 | Kensington StudioMouse Wireless...
Portable fm/am/sw radio
yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Nov 01, 2007 | Audio Players & Recorders
216 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
