Question about Technics SL-1210 Turntable
Technics SL-L3 turntable no sound until warm up
I have a Technics SL-L3, that was hit by lighting or an energy surge about 15 years ago. It worked fine up to that point. After the incident, the turntable will play records, but there is no sound through the amp. If I just let the record play, about half way through it, the sound on the left speaker comes through. It goes in and out (like when some one is messing with the speaker cable). Then about 2 mins later, the right speaker comes in. Both speakers are working and the record is playing. But if I turn up the sound I get a really loud static sound in the background. I already switched the inputs its hooked to on the amp, and the problem still occurs. I know for sure it is not the amp, because I have video systems hooked up to it and it sounds fine.
Any ideas?
  • shaftedbysoc Mar 26, 2009
    So, would I have to test the pre-amp by getting another turntable to plug into it or is there another way?
  • shaftedbysoc Apr 13, 2009
    Thanks for your help, I know that the pre-amp on the stereo is not bad. I have another stereo with a phono input, and when I plugged the turntable in it did the same thing that it did on the other amp. I guess I will try to change the cartridge and see if that solves the problem
    Genius:
  • 1,066 Answers
Either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Posted on Mar 21, 2009
How can I get a manual on how to fix this item? The arm needs adjusting. Thanks P.S. its a Technics sl-dd33 turntable
Technics website may have one. The counter weight has a setscrew on it. Loosen it ans move the weight slightly forward until the needle just rests completely in the groove and stays there. Too much will cause excessive wear to the needle and the record.
Aug 08, 2015 | Audio Players & Recorders
Owners manual for SL-L3 turntable
Two Speed Direct Drive Fully Automatic Turntable with linear tracking ... Technics SL-L3 / SLL3 owners manual, service manuals and schematics are for ... www.vinylengine.com/library/technics/sl-l3.shtml
hope this will be of help
Feb 02, 2012 | Audio Players & Recorders
I had not used my turntable for about five years due to no needle. Found a needle and played two LPs, then on the third one, it just did not move or work at all. It lit up but just acted like it had no...
The low grinding noise could be the motor spinning with "no load" i.e the belt has snapped or fallen off due to being perished.
Lift the platter to refit the belt and or replace it if required.
Jul 23, 2010 | Technics SL-BD22 Turntable
Technics SL-QL15 turntable for the charity shop?
If it still in perfect running condition, An audiophile of LPs should be interested in buying it. I sold my 30 year old Technics SL-1300 mkII for $250
Jul 30, 2009 | Audio Players & Recorders
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
Turntable turns, but there's no sound.
Well, the motor itself is completely separate from the sound. The path of the sound is basically
Styli -> Cartridge -> Tonearm -> RCA Cables -> Input Source
I would say start from the beginning. Check your stylus. If it's ok, then that means your Cartridge is probably ok. Make sure you have a secure connection from the tonearm to the cartridge assembly.
There really isn't much else to it.
If you cannot get it to work, I would suggest taking it to a service center for assistance.
- OPTiC
Electronic Repairs & Service
A DJ Pro Audio Co.
Sep 21, 2008 | Technics SL-BD22 Turntable
All my vinyl sounds warped on turntable
Most common problem is the belt getting soft, especially if it has sat for a long time. It will get a weak spot where it sat on the drive pulley and every time the turntable goes around and hits that weak spot it will slow down a little making it sound like a warped album.
The belts are usually very easy to replace. Usually just lift off the turntable or there might be a small clip on the center pin, then it lifts off. Replacement belts can be ordered from several places, as shown in this search... http://www.google.com/search?&q=SL-B200+Technics+turntable+belt
Feb 17, 2008 | Technics SL-1210 Turntable
Turntable power seems to be lightly surging
Sounds like a voltage regulator on the mothboard is going out. Avoid going in there, you really could fry yourself poking around in there. Check out these guys. They're top notch
http://www.repairnyc.com/
And Technics authorized.
Jan 12, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
624 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
