Question about Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router
Cam won't work over internet. using the microsoft wirelessMN-500
Something to do with port forwarding? how to do that?
  • 135 Answers
You'll needing to access the configuration page of the router? if you are using a router on the network. The IP address (Example 192.168.0.1) under on the advance tab you will a port forwarding to open the ports of the MN-500 wireless base station.
Note: you'll needing to call your wireless base station manufacturer to gather the ports to open on the router.
Posted on Mar 11, 2009
I am connected to the internet. I can access all websites. I have two programs "First Class" an email server and Buddy for CLZ Barry a program that connects to my iphone to receive books i have...
You have to configure port forwarding in your router. Do you know what ports are used by "Buddy for CLZ Barry" and "First Class" (it probably uses port 21)? After you figure out the port numbers, follow the port forwarding steps documented in the router manual. Here's the link to the router manual:
http://help.cableone.net/HSD/Modem/PDF/SBG900_User_Guide.pdf#page=51
Sep 02, 2011 | Arris SURFboard SBG900 Wireless Router...
I cannot get my ps3 game to work. it says to consult my routers user manual to enable the setting in the games booklet. i cant because the manual has been lost. it requires a UDP port 9301. and i need to...
You'll need to setup port forwarding on your router.
From a computer use an internet browser such as Internet Explorer.
Assuming the router is using default settings.
1) In the address bar type in 192.168.1.1
2) You'll be asked for a username and password. Username is 'admin' and the password is 'password', no quotations.
3) Click on 'Port Forwarding / Port Triggering' on the left side bar.
4) Click on the Port Forwarding radio button.
5) Click the 'Add Custom Service' button.
6) For Service Name call it something meaningful, such as 'PS3.
7) For Service Type choose 'TCP/UDP'.
8) For starting port and ending port use '9301'.
9) For server IP use the IP address of the PS3, you can get this in the PS3 menu under Network Settings.
10) Click Apply
UPnP is supported by your router. On the left side bar, click 'UPnP'.
Feb 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Port forwarding
As i remember all port forwarding was under Virtual Server configuration. But you need to check maybe web cam is using more then 1 port. Try to play with netstat to see, to which ports Connection establishing when you are connecting to cam.
Apr 19, 2010 | D-Link AirPlus DI-524 Wireless Router
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
Will go to test xbox internet connection will say up and running but will be a yellow triangle with ! in it that will let me know i can not run xbox live to the fullest. when playing halo wars i am kicked...
does it say your nat is low? or something about nat. you probably have to forward your ports.
http://support.microsoft.com/kb/908874
and heres the fix
http://www.google.ca/#hl=en&source=hp&q=forward+ports+for+xbox+360&btnG=Google+Search&meta=&aq=f&fp=a1047c2a76fad57b
http://www.youtube.com/watch?v=nMcddyHoHZg
Aug 23, 2009 | Microsoft Xbox 360 Console
Can play online but says cant sign into messinger
The "Can't connect to messenger" error does not apply to in game chat or voice messaging, but only to the version of MSN that can be downloaded from xbox LIVE. Go to network settings, then test the connection to the internet. If it says that your NAT type is moderate or High, you need to do some port forwarding on your router. You can find how to do this on Xbox's main site. The port to be forwarded needs to be number 3074. (or something to that effect)
Feb 11, 2009 | Microsoft Xbox 360 Console
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
VPN
the following is from a nice guide i found on the net, see if it works for you: First thing to check is whether your router has any settings for PPTP or IPsec "pass through". These are commonly found in Linksys routers but you may have to hunt around for them on other makes. All you need to do is enable the setting for the VPN protocol that you're using, reboot your router and, if you're lucky, the VPN connection will come right up. Note: Not all routers have these enables and the lack of them doesn't necessarily mean that you can't get VPN working. Open up that Firewall Still no connection? The next step is to try opening some ports in your router's firewall to get your VPN connection made. In each case, you'll need to open the specific ports (and protocol) to the IP address of the computer that you're running the VPN client on. NOTE that port mappings work with only one computer at a time. If you have multiple VPN clients that you need to connect, your router will have to support the VPN protocol that you're using without requiring ports opened. If you're using Microsoft's PPTP protocol, TCP port 1723 is the port you'll need to forward to allow PPTP control traffic to pass. Figure 2 shows the Forwarding screen on a Linksys BEFSR41 set to forward this port to a client with IP address 192.168.5.100. PPTP also needs IP protocol 47 (Generic Routing Encapsulation) for the VPN data traffic itself, but note that this is a required protocol, not a port. The ability to handle this protocol must be built into the router's NAT "engine"?which is true of most present-generation routers. IPsec-based VPN's need UDP port 500 opened for ISAKMP key negotiations, IP protocol 51 for Authentication Header traffic (not always used), and IP protocol 50 for the "encapsulated data itself. Again, the only "forwardable" item here is UDP port 500, which is also shown programmed in Figure 2 to the same LAN client machine?protocols 50 and 51 must be built into your router. Tip: Not all routers are created equal! Some allow only one VPN tunnel to be opened and used by a single client. Others support multiple tunnels, but with one client per tunnel. Unfortunately, most vendors don't make the VPN pass through capabilities of their products clear in their documentation, nor do they have support staff properly trained to provide this information either. In most cases, your only option is to try a router in your specific application, and make sure you can return it and get your money back if you can't get it working. Still not Working? Getting many IPsec-based VPN setups working can be a black art due to the wide variation in techniques used by various vendors. Although IPsec products have become more uniform as the technology matures, your company may use older, more proprietary products that may not be configured with NAT in mind, or require additional ports to be opened in your firewall.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
Microsoft Broadband Networking MN-500 Wireless Base Station (L21-00001) Router Logo
85 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
