Question about GE 106591 Coffee Maker
Brews 1 cup at a time - GE 106591 Coffee Maker
  • 34 Answers
The Micro fuse is opening and closing and almost completly gone.
The Micro fuse is shorted open. There are two underneath the housing. They are made byMICROTEMP® and are the G400 series rated at 216 Degrees Centigrade.
You can check these with a Ohm meter to see if you have continuity. Checking across the leads of each one they should show infinity. if not you've identified the defective fuse. You can pick up a new thermal fuse at Radio Shack. The closest one to the specs of the Microtemp is a Radio Shack part number 270-1321 rated at 228 Degrees Centigrade. Before removing the old one notice which way the hat end faces. As cheap as they are I would replace both at the same time ($1.50 each).
Use a heat sink when soldering the new thermal fuse in place by using alligator clips or a pair of pliers. Reassemble and your back in business as a Barista.
Note: There are four Phillips head screws under the rubber pads. The three unusual screw heads may be removed/installed with a small screwdriver installed in just one of the slots.
Posted on Apr 25, 2009
SOURCE: Slow brew time / water disappears?
I have this problem with a 4 cup model. 4 cups in, 2 cups out. I cleaned it twice with vinegar (with a filter in place). The first time didn't seem to help, but the second time I got about 2.5 cups out, along with a bunch of old grounds that I think had been sucked into the pump. Ran water through it twice, and now it gets to about 3 cups.
I think the problem is just that the pump is clogged with grounds. If vinegar makes yours worse my guess is that a big piece got dislodged and is now blocking the tube. More vinegar might help.
Posted on May 01, 2009
  • 60 Answers
SOURCE: hit brew coffee and it only brews 1/2 cup instead
Descale the brewer
Posted on Mar 23, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Our machine has been descaled two time using the
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
dssfdfs
Posted on Dec 22, 2010
SOURCE: my keurig only brews 1/2
The next time you go to brew a cup, open the lid to the water well and locate the little clear rubber spout that sticks out of the side of the machine toward the top. When you brew the cup watch the spout to see if water is coming out of it into the water well. If it is you can just put your finger over the hole and the machine should brew the whole cup.
I usually only have to do this once every time the problem starts happening, but it is clearly not a permanent solution. I assume the problem is with a valve inside the machine or something, and to fix it permanently you should probably get the unit serviced or exchanged under manufacturers warranty.
Posted on Feb 03, 2011
heatman101
  • 43501 Answers
SOURCE: keurig coffee maker isnt working--water brews
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on May 21, 2011
It brews only a third of a cup. it is a TAS4511UC
No clue, I avoid those gimmicky 1 serving machines. They are expensive to operate and hard to fix.
Oct 07, 2014 | Bosch Tassimo TAS4511UC Coffee Maker
Kuerig keeps brewing without pushing button
my kuerig has water come through the k cup when I close the top without pushing brew cup size and if it does let me make a selection it brews 1/4 of cup I have descaled it 4 times locked in the water reservoir cleaned the needles turned it on and off any other suggestions to try would be greatly appreciated thank you
Nov 08, 2013 | Keurig Coffee Makers & Espresso Machines
Only brews one cup at time
Open this website and choose on the right side "DOWNLOAD USER MANUAL"
http://www.cuisinart.com/parts/coffee_bar/dcc-2000.html
Jan 13, 2013 | Cuisinart DCC-2000
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Aug 01, 2009 | Keurig B50 Coffee Maker
Instruction manual for cuisinart auto grinb and brew 1 to 4 cups
Here is the trick with the Cuisinart Grind n Brews - their proportion sizes are based on a 5 oz cup - most coffee cups are about 8 oz cups - so you really need to use more than they suggest, but here is their reccomendation:
We recommend you use 1 scoop of whole
beans per cup. Maximum 14 scoops.
For 1 or 2 cups, use 1-1/2 level scoops
per cup. Adjust the recipe according
to individual taste.
Mar 25, 2009 | Cuisinart Coffee Makers & Espresso...
Coffee maker brews too hot
The 1-4 setting makes the coffee extremely hot. If the 1-4 setting was not activated, make sure you are not using paper and permanent filters at the same time. If you are not using them at the same time, it is time to clean the coffee maker out with 2 cups vinegar and two cups water.
-Tha Mp3 doctor
Nov 03, 2008 | Cuisinart DCC-1200 Coffee Maker
May 20, 2008 | Mr. Coffee ISX23
GE 106591 Coffee Maker Logo
128 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
