Question about Electrolux Epic 6500 Vacuum
Electrolux Vacuum keeps turning off and light looks like bag with
My electrolux epic series 6000 series keeps turning off. I replaced the bag with brand new one twice. Cleaned area hoses and inlet hose, vacuum is not plugged, just seems to turn off and light comes on shape of bag with dots in the middle. Turned off and on a couple times, still no help.
help please
  • 3 more comments
  • Anonymous Mar 18, 2009
    I have the same problem. Bag is new and it still turns off and lights the bag with a cross hatch patern. And what is the dial on the top supposed to do???
  • sloanlake Apr 01, 2009
    Began with a clog in the hose.  That is completely clear now, but when i turn on the bag, sensor light kicks in and turns off machine.  The bag and filter are new.  Even when hose is disconnected, just passing hand over hose connector will cause it to shut down.
  • btheprincess Apr 27, 2009
    I am having the same problem. I put 2 new bags in and it turns on for a second and then turns off. The light comes on that shows the bag full, but the bag is brand new. I can turn it on without the hose, but as soon as I put my hand in front of it, it turns off again. PLEASE HELP!!! Thank you!
  • Anonymous Mar 12, 2014
    Shuts off immediately checked safety switch. For bag seems ok rotated dial on top and now works for awhile. Will run with hose attached. Hose is not plugged.
  • Cate Melvin
    Cate Melvin Dec 02, 2016
    I fix these machines at an Aerus franchise. It is the full bag sensor. It is actually borken. Turning the knob will allow you to fill the bag too full or not full enough but eventually even that won't help. Take it to your local Aerus franchise for replacement of the broken part(s).
  • 73 Answers
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Posted on Aug 27, 2009
I don't have a solution, but I have exactly the same problem.
Posted on Aug 23, 2009
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
What kind of bag for the epic series 3500 sr
"U" (upright) style bags, available at any Aerus Electrolux store, or from their consultants. These are the genuine bags made only by Home Solutions. Generic bags WILL decrease the lifespan of the motor.
Contact your local dealer. Free home delivery.
http://www.aerushome.com/storelocator/
Nov 15, 2010 | Electrolux Epic 3500 Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
What is the symbol above the "change bag" symbol?
When the bag is full, the "full bag" light will come on and will turn itself off. Replace bag (make sure there is no clog) and try again.
Hope this helps.
Aug 17, 2009 | Electrolux Epic 6500 Vacuum
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
1,763 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
