Question about SanDisk Sansa Fuze MP3 Player
My computer does not detect my mp3 player sansa 4.0 gb
I have windows xp iit wont detect my mp3 player? Can you please help?" my computer doesnt recognize my mp3 player. i have a sansa fuze 4gb mp3 player, and windows will not show it or recognize it in any fashion other than beeping at me when i plug it in. any suggestions? My Sansa Fuze 4gb mp3 will beep and look as if it is beginning to charge when I plug it into my laptop, and I can see the files on the Sansa through the my computer on my laptop, but it won't accept new files and it won't actually charge. It charges off of my other laptop, so I know the problem isn't with the mp3 player.
  • 54 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Posted on Mar 10, 2009
SOURCE: problem with Sandisk Sansa fuze
SCREEN CRACKED BY ACCIDENT. IS THERE A WAY I CAN CHANGE IT FOR A NEW ONE
Posted on Jun 21, 2008
  • 24 Answers
SOURCE: my computer does not detect my mp3 player sansa 4.0 gb
try to reset it
Posted on Oct 17, 2008
SOURCE: my sansa fuze 4 gb will not charge or now won't turn on.
what is a bit muda?>?>
Posted on Oct 15, 2009
  • 5 Answers
SOURCE: My Sansa Fuze 4GB froze. It doesn't turn off or
try holding the power slide/ button type thing in the on position until it turns off, then try turning it back on...
Posted on Nov 22, 2009
YourZEN
  • 820 Answers
SOURCE: why is there no manual with my sansa fuze
For the Sansa Fuze there's a manual available in pdf format on the Sandisk support site:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Save this file to a location on your computer for later use.
When you explore "My Computer" the micro SD card with x GB memory, should be available as an extra external drive.
This drive will show up as an extra drive letter with a total capacity of x GB .
Posted on Apr 24, 2010
My sandisk e 250 one gb ipod is not detecting in ubuntu 10.04 but is charging
you must follow 5 steps
1) connect ur device to windows xp or windows 7
2) go to sansa website download sansa updater and install it
3) then follow instructions by sansa updater it will then automatically search and install a program for detection of mp3 player on ubuntu install that program its around 16mb .the software will do this you just follow this
4 after completing sansa updater instruction ,go to settings you can now see a usb mode then change to msc mode for detection in ubuntu
5 for detection on windows change to mtp mode
Oct 22, 2010 | SanDisk Sansa e250 MP3 Player
When I plug my Sansa Fuze (8 GB) into the computer it won't download the driver into the computer.
if u have a installer cd with the device then
please install the driver then plug your device
in the connectivity cable.
Dec 28, 2009 | SanDisk Sansa Fuze MP3 Player
Computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Jan 02, 2009 | SanDisk Sansa e260 MP3 Player
either unplugg it and try again or try a diff usb port
Jul 22, 2008 | SanDisk Sansa e260 MP3 Player
i just had that same thing happen make sure that you turn the mp3 on then off and then try to reconnect it to the usb port
May 12, 2008 | GPX MW3836 MP3 Player
Sansa m240
You do not need anything from the CD, it only has Windows Media Player 10.
All you nee is a PC with XP / SP 2 and Windows Media Player 10 or higher. No drivers are necessary.
Best of Luck.
Please RATE my solution BELOW.
Nov 22, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
Wont let me add songs !!HELP!!
Try downloading the MEDIA MONKEY. Its better than windows media player and itune. It automatically detects any mp3 players and you can synch your mp3 player without any problem. Whether you are using vista or xp the media monkey is way better than windows media player.
Aug 31, 2007 | SanDisk Sansa e250 MP3 Player
If you have Windows XP / SP2 and Windows Media Player 10 or higher. It should be recognized. If you have these, try changing the mode to MSC. Best of Luck.
Aug 23, 2007 | SanDisk Sansa c150 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Fuze MP3 Player Logo
405 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
