Question about Husqvarna Viking 1
Viking scandinavia 400 everything goes to zero
I can sew a few stitches and then all the thread tensions go to 0 and it just beeps. It wont let me select any decorative stitches and I am unable to use the embroidery table. I have unplugged and let it sit and it still does the same thing. I have been told by one person it could be a thread jam somewhere in the machine. This problem was all of a sudden and not after a thread jam. If anyone could help me figure this out I would greatly appreciate it.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
To answer exactly, I need more information.
Is anything flashing in the main screen? The foot? the spool?
Posted on Mar 19, 2009
Problem with Viking Scandinavia 400 embroidery machine
it's possible that part of the computer is mal-functioning or going out
having the machine checked would tell what it is for sure
Mar 20, 2012 | Husqvarna Viking 1
Husqvarna viking, scandinavia 400: bobbin issues
try decreasing the tension to 3, if that doesn't help I would suggest to have it checked if it's still under warrenty
also is the fabric & needle & thread compatable?
Feb 27, 2012 | Sewing Machines
Thread bunching up around bobbin
If you do not have a user guide, you might want to find one. Try ebay or have an authorized Husqvarna Viking dealer order you one. In fact I would find your nearest authorized Husqvarnia Viking dealer and visit them with you machine. They should be able to help you and usually are very helpful even if you didn't buy the machine from them. If they determine it is correctly threaded and the bobbin is ok, have it serviced by an authorized Husqvarna Viking dealer or have them send it to Husqvarna Viking (SVP) Technical Service Dept in Tennessee for service. The machine should give you years of good performance.
Use only genuine Husqvarna Viking bobbins.
To find an authorized dealer near you, check the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Sewing Machines
Viking Designer 1 balleds / Birdnest / issues after repaired from Husk service center in midwest - replaced thread needle and adjusted tension .. freequilting and embroidery situations
birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
scott
Jul 26, 2009 | Husqvarna Sewing Machines
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Viking 1+--Thread breaks during embroidery
If the thread will not run through the tension mech on 0 then it is probably stuck on a tight setting. It can be a bit complicated but the tension mech can be stripped/cleaned/free'd up. Another possible cause is the path of the thread from the spool to the needle any deviation from the correct path increases the tension at the needle. If you do not know the history of the machine I would suggest a thorough clean and service.
Mar 23, 2008 | Husqvarna Viking 1
Sewing Machines Logo
250 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
