Question about Sony Televison & Video
Sony Bravia Sync Selects Wrong Input
I have a 40'' Sony FullHD LCD TV and recently got a Sony HT-DDWG800 component hometheater system. The home theatre is connected to the TV via HDMI to HDMI input 1. A satellite decoder is connected to the theatre using SAT but only the RCU inputs and the coaxial for audio for DVD is assigned to SAT as this more superior sound than the optical input. Monitor out from Receiver also goes to the LCD video1 input.
When I enable Bravia Sync on both LCD and Receiver, power off on TV/Reciever switches off the other. Now when I select Video1 on TV to view Satellite decoder ( Reciever switches to TV input! When I select SAT on Receiver, TV input selected is HDMI1. My satellite decoder is not HD as this model not launched yet. How do I make the Receiver switch to Video1 when I accept Video1 on the TV? When TV channel is selected the Reciever switches to TV which is fine. When I select Video1 I want to be able to watch Video1 input on Reciever. I have no problem with the LG DVD player connected to DVD input via HDMI as this automatically puts TV to HDMI1.
Why does the Receiver select TV when I set TV to Video1? Why does the Receiver on SAT put TV on HDMI when there is no HDMI connected on SAT?
  • 81 Answers
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
SOURCE: Auto Switch does not work for HDMI inputs
Try this:
Posted on May 17, 2009
  • 814 Answers
SOURCE: My tv keeps defaulting to the Video1 blue screen.
You must take your unit in for servicing for intermittent control switching ic problems. You may just have some bad solder joints that appear after periods of use. You may also have failing solid state components like the switching ic or supporting components. It is best to have the unit tested and repaired in a service center where they have all the service infromation. You can call insignia customer support at 1-877-467-4289 You can also check the Insignia website for customer support at I hope this information helps you with your problem.
Posted on May 22, 2009
  • 274 Answers
SOURCE: Hi. We have an old analog TV (Sony) which has a new digibox running through it (since the switch over). Was fine, but over the last few weeks, intermittently, the screen goes black with EXT 1 in the t
Your picture tube is on the (Verge) Of going.
Posted on Oct 09, 2012
  • 3103 Answers
SOURCE: Toshiba Dvd won't work properly with my new TV
if your old tv was an analog one you need a digital converter box to change to the new signal.. new tvs wont recognize the analog signal..temporarily you may be able to use your laptops' dics player as a player for your discs..
Posted on Jan 11, 2014
My sony tv has a line across the screen that says bx42, full hd1080p, digital noise reduction, usb play, hdmi2, bravia sync, pc input, 24p true cinema and i cant get rid of it.
Hi mike harris,
i think your TV is on demonstration mode.
To turn off the demo mode, press and hold the HOME or MENU button on the TV for more than 10 seconds. The messageDemo mode: Off will appear on the screen.
Mar 02, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Home theatre 5 disc changer, DAVHDX975WF and a BDPS560 Blue-ray player connected to a 46" LCD TV KDL46XBR10. The HT has been the speakers for the TV since day one. The Bravia Sync...
it is most likely bc of a firmware update. i have heard of this problem while working at best buy. rarely do i see the bravia link actually fail. i would shut both off for a little while and connect them without the link then connect the link. kinda like a reboot of the whole system . hope this helps!
Mar 15, 2011 | Sony Audio Players & Recorders
Does this model have Bravia sync?
Yes it does per SONY web site:
BRAVIA® Theatre Sync™ technology
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
Feb 02, 2011 | Sony BRAVIA KDL-40V3000 Television
Can not get my Samsung TV to recognize the ht system. I am able to get the sound out of the ht system and the video on the tv when i play dvds but the sound will not transfer from the tv to the ht system...
The way mine is hooked up is like this: Ps3, DirecTV box all plugged to my samsung TV and then only thing I have plugged into the Ht box is the hdmi out to TV and an Optical Cable from Tv to HT box. All audio is going to Tv then to HT box and plays all through hometheater box when it is on. Try the optical cable
Sep 22, 2010 | Samsung HTC650 Theater System
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Open Questions:
Televison & Video Logo
1,092 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
