Question about BSA Air Gun Scopes
Crossman Phantom break barrell air rifle will not **** after breaking the barrell open. Any suggestions as to the problem?
  • 20 Answers
The barrel pushes the piston back when you **** it.
The seer grabs the piston to hold it.
It sounds like you have an engagement issue between your seer and piston.
Often there are springs which hold the triger paul and seers in place. You may have lost a spring which isnt allowing your trigger mechanism to reset after the trigger is pulled. This results in the trigger being permanitly in the fired position.
Good luck and hope this gives you something to look for
Posted on Aug 19, 2009
  • daisyman1 Aug 19, 2009
How to fix air pump
The crossman phantom is a spring powered air rifle which means that you pull the barrel down through the arc of its travel until the piston locks up to the trigger mechanism in one continuous movement
Feb 08, 2016 | Crosman Optics
Air leaks out when installing co2
The Phantom Break-Barrel does not use CO2. It is a spring-loaded break-barrel weapon. If you really do have a CO2 gun, check the rubber seal around the outside of the cartridge puncture needle.
Feb 18, 2011 | Crosman Phantom .177 Caliber Break Barrel...
I have a crossman phantom model cs1k77bv lost manual need to know where to put oil
Go to Crosman's web site for manuals:
http://www.crosman.com/cs/manuals/crosman-rifles
Jan 30, 2011 | Crosman Phantom .177 Caliber Break Barrel...
Need a repair manual four a crossman 177 cal pump need to put it back together
found a picture how the trigger and springs set up worked all i needed was where one spring went.didnot find a manual on the web. thanks
Mar 10, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Will not chamber a pellet for Crossman 357 .177 cal pellet gun
http://www.pyramydair.com/site/manuals/Crosman-2100.pdf ,
Read this and make a decision based on the information contained within.
Feb 06, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Lost owners/users manual
go to this site http://www.pyramydair.com/site/manuals/Crosman-2100.pdf
Jul 09, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Jun 01, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Co2 leaks from chamber on crossman modle400 rifle how do i fix it
Check thare is a rubber o ring missing or broken in the air chamber
Mar 29, 2009 | Crosman Phantom .177 Caliber Break Barrel...
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
Feb 08, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Optics Logo
415 people viewed this question
Top BSA Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a BSA Optic Expert? Answer questions, earn points and help others
