Question about Sharp AL 1631 Copier
Sharp AL-1631 When you turn the copier on & when you try to copy I get a LOUD clicking noise. I believe I have figured out that it is coming from the top feed roller - the one you can turn using the green knob inside where you put the toner cartridge in. Any suggestions and / or is it worth trying to repair - it is over 4 years old.
  • 29 Answers
There is severl thing this could be 1. paper feed cluch need cleaned 2-bypayss roller lift arm need removed, 3-or the drum unit need clened out . all thses thing can be dones easilly by a sharp tech about $120 should do it. note this is the only model of copier left that you can refill the toner unit for $6 & drum for $15 ( id keep it )
Posted on Mar 10, 2009
4 Suggested Answers
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
  • 29 Answers
SOURCE: FEED ROLLER Sharp AL-1631
Percision roller phx arizona also have web sight
  • 990 Answers
SOURCE: i have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Posted on Feb 08, 2010
When i close the back door it is making a loud noise. sharp al 1631
If it sounds like gears grinding it may be the fuser unit. The bushings and gears need replaced or new fuser unit.
Aug 31, 2010 | Sharp AL 1631 Copier
SHARP AL-1631, SCANNER NOT MOVING WHEN MAKING
You try any zoom copy, I maen 80% small then move scanner.
Apr 21, 2010 | Sharp AL 1631 Copier
I have a sharp copier AL 1631- it's making a noise
Feb 08, 2010 | Sharp AL 1631 Copier
A loud clicking sound
This means that a gear is jammed or broken somewhere. Check for waste full and empty or drum waste roller and unblock the jammed toner inside that unit or check fuser gear if broken then replace it.
Nov 23, 2009 | Sharp AL 1631 Copier
Loud clicking noice during copying
take the toner unit out check toner recovery bottle on the front of toner unit, empty or vacum it out dale, if not that could be gears on the machine drive, or fuser, or down in the by-pass dale
Feb 14, 2009 | Sharp AL 1631 Copier
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
SHARP COPIER AL-1631
2 things:
1. Fusing Unit has to be replaced- worn or broken gear
and/or
2. Main Drive clutch has to be replaced.
Either way it has to be done by a trained technician.
Dec 24, 2008 | Sharp AL 1631 Copier
Al 1631
Simple you get a PM, new developer.. call an authorized Sharp Tech...
Oct 21, 2008 | Sharp AL 1631 Copier
Woodpecker noise II
A technician should look at this. There could be a gear going bad on it. Ive see a fee cases where the drum gets bad and cant turn any more.
Are there error codes on the screen?
Make sure the right door where the bypass tray is closed all the way.
Jun 16, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
259 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
