The readable screen has been reduced by 1 inch on either side. This happened once before but I do not remember how I fixed it. This screen size makes it impossible to read some web pages fully. Can you help me correct this problem?
  • 6 more comments
  • knliha1 Mar 11, 2009
    Where do I go to adjust the horizontal and vertical screen? I need detailed instructions. Thankyou.
    Where do I go to reset the screen to the default settings. This is a Laptop I don't have a monitor.Do I go to (my computer at start)
    This lap top doesn't have any buttons on the front. And I'm not sure it has a monitor like a pc.
    I'm sorry but there is no button on the screen to reset. Could you tell me where to look for it. As you can tell I am definatly not good at this.Would it be on the keys themselves?
    I right clicked on properties and there is no settings tab located there.Im not sure there is a button on the monitor anywhere.
    CuLeBrO solved the problem. Hurrah!!! so thankful.
    Is great to have a service like yours because I find problems with computers frustrating and getting solution satisfying. Appreciate all of you thanks again.Knliha1
  • Larry Rider
    Larry Rider May 11, 2010
    Right click on desk top /display properties/settings/change screen resolution/apply. do this at one of the settings your screen will be right. To fix problem go to your PC manufacturer and search support for settings for your make and modal. If you have a problem with that let me know make and modal. mysleuth
  • ltoso May 11, 2010
    this can happen due to two reasons
    one the resolution of your screen has changed settings fo monitor have changed
    push in the menu button your monitor and restore your monitor settings to factory settings or default settings, if this option doesn't exist or doesn't work
    try adjusting the width of the screen using the bottons present on the monitor.
    Further Queries are welcome
    Please do rate my answer if you find it helpfull
    Genius:
  • 1,239 Answers
Hi
go to control panel>appearence and personalization>adjust screen resolution,,,>advanced options and enter ur resolution size and check it now...or go to control panel in search type system restote...it will fix to normal without deleting files.. or if upgrade ur operating system actually the poroblem will be solved,, thank u.,,,,,,,,,
Posted on Mar 11, 2009
  • 679 Answers
Try holding down the Ctrl and hit the + sign, it should open it.
  • George Bill
    George Bill Mar 11, 2009
    Also if that doesn't do it go to tools on your IE toolbar, and click on "fullscreen", you may have resized the screen by accident
  • 54 Answers
Hi
Go to Start --> Control Panel --> Display
If you don't see the option "Display" clic in the option "Switch to Classic View" located at the upper left panel, and then double clic on "Display".
Clic on the tab "Settings"
There is an option called "Screen Resolution" which has a slider control, keep press this object and slide it from left to right step by step, at each step clic on the "Apply" button.
The screen will turn completely black for a couple of seconds and will be back with a new window asking you if you like your new settings while a timer counts down from 15 seconds, if you like your settings clic YES, if not, clic NO or let the timer count down to zero and your old settings will be back.
Good Luck!!!!!
  • 4,806 Answers
Hi there.
In Vista right click on the desktop and select "personalize" then select "display settings" and set the resolution to 1024x768.
In XP right click on the desktop and select "properties" from the menu select the "settings" tab and change the resolution, if this does not work look at the monitor for the menu button there you will be able to stretch the screen.
Good luck and thanks for using FixYa!!
  • Lee Hodgson
    Lee Hodgson Mar 11, 2009
    hi there.
    you right click on the desktop, and left click on properties
    Apologies
    Novelist:
  • 148 Answers
Hi
push in the menu button on your monitor and set it to default/factory settings if this doesn't work or the option is not present
set the width of your screen using buttons present there
further queries are welcome
  • 1 more comment
  • ltoso Mar 11, 2009
    hi,
    if its a laptop
    right click on the desktop go to properties > settings > screen resolution
    adjust the screen resolution from here according to your needs.
    do you remember the time it was the way was i mean the date, if you remember the date, you can do a system restore it will restore your system to the date it was working fine here is a helpfulll link to system restore
    http://support.microsoft.com/kb/306084
    ok try this
    click on start button go to run type in without quotes
    "devmgmt.msc" press ok
    in the window click on the plus sign next to display adapters and then right click on the item below it and select uninstall, thsi will uninstall the display adapter and then restart your system and when your system will be restarted it will either install the display adapter again and reset the screen size automatically if not it will prompt you for the driver CD to install the display adapter and once they are installed it will work fine.
    Scholar:
  • 150 Answers
Does your monitor have buttons on the front? Press the menu button and navigate until you find the screen size, and stretch it out to the edges of the monitor, it sounds like it's cutting off the sides of the page, if that's the case it's definitely that the monitor defaulted to the smallest possible size. Just stretch it out on the monitor with the buttons themselves.
  • Kurtis Stalnaker
    Kurtis Stalnaker Mar 11, 2009
    You posted this problem in PC desktops, leading us to believe that it was a desktop issue, please be clearer next time. Right click the desktop and go to properties, then go to settings and set the screen resolution to 1024x768 and see if this fixes the problem.
  • Kurtis Stalnaker
    Oh yes there is,
    http://www.optimizingpc.com/install/desk...
    Scroll down to
    Screen Resolution and monitor settings
  • 6,784 Answers
Hi, you can reset the screen to the default settings. once you do this, the screen will revert back to the slandered form. you can also adjust it by accessing your video card software as well. the reset option on the monitor is accessible by using the buttons on the monitor itself. Just hit the menu button on the monitor and select reset.
Posted on Mar 10, 2009
    Genius:
  • 1,550 Answers
Is it desktop then adjust the horizontal and vertical screen .
  • SAM ANDERSON Mar 11, 2009
    In laptop , just right click on the desktop -> click properties ->click settings tab in it ->change resolution .
    Top Expert:
  • Computers & ... Master
  • 77,544 Answers
THE SCREEN SHOULD HAVE AN AUTO RESET BUTTON, THIS WILL RESIZE THE SCREEN.
Has 2 inch main water line and 3/4 Inch meter.can I reduce size of pipe to 1 inch
Yes if you reduce the size it will not affect the metre you could reduce to 3/4 and 1/2 for house use.
Dec 18, 2015 | Refrigerators
My picture display is narrow and does not cover the screen.
Does the Genie box have screen settings in in? Sometimes hd will show in smaller screens. Makes the picture nicer. If you adjust the screen size with your remote the high definition "niceness" will not be there.
Jul 30, 2014 | Seiki Televison & Video
When I play dvds or watch videos on youtube the screen has a black border on both sides reducing the size of the screen
If you hit full screen on the youtube video and its not full screen, then it sounds like your monitor resolution is to low.
Rt click on a place on your screen and pick screen resolution, then pick resolution and increase it.
The first number is width, so say it's on 800x600 then go 1024x768
Apr 05, 2013 | ASUS Computers & Internet
I WOULD LIKE TO ENLARGE TYPE ON MY SCREEN
To increase or decrease the size of objects and text on your screen 1.
Open Display in Control Panel.
2.
On the Settings tab, click Advanced.
3.
On the General tab, in the DPI setting list, click the dots per inch (dpi) setting you want to use.
4.
If you choose Other in the DPI setting list, you can set custom options in the Custom DPI Setting dialog box either by selecting one of the percentage options in the drop-down list or by clicking on the ruler and dragging the pointer to specify a setting.
5.
Restart your computer when prompted.
Note
• To open Display, click Start, click Control Panel, click Appearance and Themes, and then click Display.
• If you want to increase the size of text on your screen to make it more readable, use Font size on the Appearance tab in Display Properties.
• The dpi size you specify on the General tab affects all monitors attached to your computer and all users that log on to the computer.
Jun 21, 2011 | Computers & Internet
2 thin lines from top to bottom 5-6 in. from ends of screen.
if your set is a plasma then that can happen .. LCD screens are not known for that problem but it does happen to them also .. sometimes you can balance the screen a bit better by leaving a blank bright screen on for an hour or so ... also just playing wide screen often reduces the effect over time .. DLP type projection TVs dont normally do that but LCD and CRT type projections can .
Jun 24, 2010 | Televison & Video
RE: SENDING FAX
The scanner glass is dirty or needs replacement. lift up the scanner door where you put original in. See the glass strip 1/2 inch by about 8 inches. clean with alchohol good. dry. test. Lawrence
Jul 18, 2008 | Sharp FO 77 Roll paper Thermal Fax
Page size too large for my screen.
I have windows xp home edition and would like to shrink my page to screen size without reducing font size.
May 24, 2008 | Compaq Presario 1800T Notebook
PC does not hold the monitor wide screen setting.
Do you mean your internet explorer window?  You need to stretch the explorer window to the size you like, then close, it.  IE remembers the size of the last window you closed, and then when you open it, it makes the new window the same size as the last 1.
Hope this helps.
Oct 12, 2007 | Computers & Internet
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
