Question about Dell Dimension 5100 (D51L1) PC Desktop
Still cant get my second hard drive to work?
Right, have connected second hard drive inbetween the dvd drive and floppy disc, it is connected under the dvd drive, and the dvd drive is set to mast my drive is set to slave, this drive is not faulty as its only gone from one computer to another no where inbetween! the computer doesnt detect it in bios or computer management! and iv checked like 30 times if its plugged in correctly any 1 had this problem? maybe its just the dell
  • 5 more comments
  • yeboi Mar 10, 2009
    no i didnt, i disconnected my dvd drive just now, and it now has recognized teh hard drive and all my stuff is there? and ideas how to resolve this 1? the dvd drive is set to master and the HDD is set to slave ?
    na they are correct!! my seagate hard drive is blank which is wat it needs for slave and i moved the dvd drive about 20 mins ago! from umm sumfink to master i cnt quite remember wat it was it wasnt slave it was like cable summin!
    um i put them both on cable select as you suggested now it cant find either of them? any ideas thanks for trying its really appreciated
    right it now appears in bios as the hard drive so where do i go from here? it appeared just by changing it to master didnt try swappin ports!
  • Nicolas
    Nicolas May 11, 2010
    OK! but still, if you dissconnect the dvd the disk works fine it must be the master/slave settings. Sometimes you need to follow the connectors on the cable to, one is for the master and one is for the slave. If you connect the master connector on a slave drive it might not work.
    Nic
  • Nicolas
    Hi!
    Hmm...it sounds lite the pins for master/slave isent correct on either the HDD or the DVD...check them again
    Nic
  • David Koss
    David Koss May 11, 2010
    Did you go in the control panel and click on add hardware wizzard?
    President:
  • 2,653 Answers
Try setting the dvd drive and the hard drive to "cable select"
Let me know what happens.
Posted on Mar 10, 2009
  • RescueTechLA
    RescueTechLA Mar 10, 2009
    LOL
    OK let's take the dvd drive out of the mix for the mean time. Change the hard drive to master then plug the ide cable back in, if it doesn't detect in the bios, try the other ide port on the cable.
  • RescueTechLA
    Now set the cd / dvd drive to slave and see if the bios detects both now.
Computer will not boot hd and dvd/cd drives
first check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
check that there are no CDs or DVDs 3 1/2 inch floppy discs
in the CD/DVD,3.1/2 floppy drives ,and no removable usb drives plugged in to the usb ports
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Mar 21, 2012 | Computers & Internet
Bad bios checksum..my cd rom could not detect or read the p4v8x-x enev i rename them and it's still the same, then i try to put the .rom file into floppy,,it detected ! But keep restart. (Checking for...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 13, 2011 | ASUS P4V8X-X Motherboard
OK so when i turn on my computer it says that the NLDTR is missing before i get to my desktop. right from the get go it will be on the loading black screen and it will say "NLDTR IS MISSING"...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 20, 2011 | Microsoft Windows XP Professional With...
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
don
The computer only boots up to the point were it said's floppy diskette seek failure... strike the F1 key are F2 to run the setup utillty. neather funtion works
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 05, 2011 | Dell Dimension 8100 Motherboard (5E692)
My hard drive is not clicking but i cant format it. how to format? it says disk error
you can click on computer then right click on the drive that you want to format the you will see the option FORMAT,or you can use a recovery disc and do a clean install,how to do a clean install? put the disc on the dvd drive nad then turn off the pc,turn it back on then keep on tapping f12,select boot from cd/dvd or boot from odd
Jun 12, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Where do you insert a disk in a laptop
Check in right side of laptop .
You find i small button press it so you cna ejct it.
Also you can find with my computer .
open my computer thne right clcik on your cd drive icon then click on EJECT so your disk drive is eject.
Put your disk there.
Let me know if you need more assistanse.
Thanks.
Aug 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Boot failure Asus P5Q-EM
Disk boot failure. Issue:Disk boot failure.
Cause: This issue could be caused by any of the below possibilities.
  1. Boot options are not set properly in CMOS
  2. Non bootable disc or USB in computer
  3. Remove added hardware /check connections
  4. Hard disk drive is bad
Solution:Boot options are not set properly in CMOS
Verify that the boot options within CMOS are set properly. Below is an example of how we recommend the boot options be set. Additional information about how to enter CMOS can be found on document CH00192.
  1. Floppy drive
  2. CD-ROM drive
  3. Hard Drive
  4. Other / Network
Non-bootable floppy diskette or disc or USB in computer
Verify that there is no floppy diskette or disc in the computer. If the boot options are set improperly the computer could be trying to boot from the disc drive instead of the hard drive.
In addition to verifying there is no disc in the computer make sure that no USB jump drive, external hard disk drive, or memory stick is inside any memory card reader.
If you're wanting to boot from a floppy diskette, CD, DVD, or USB drive and are getting this error message and have verified that your CMOS settings are in the proper order as explained in the above paragraph the diskette or disc you're using is either bad or does not have the proper files on it to make it bootable.
  • Additional information about how to make a boot disk can be found on our boot disk help page.
  • See document CH000669 for information about creating a bootable disc.
Remove added hardware / check connections
If you've recently installed any new hardware it's suggested that it be removed to verify it's not causing this issue. If after the device has been removed the computer works and it was another IDE / EIDE device ensure that the jumpers are properly set on the hard disk drive.
In addition to removing any new hardware it's also suggested if you've recently moved the computer or installed anything inside the computer that the connections for the drive be checked. Usually it's best to simply disconnect the cables from the back of the drive and reconnect them to make sure they're connected properly. While inside also disconnect and reconnect the cable connected to the motherboard as well. While inside your computer make sure you're aware of ESD.
Bad hard disk drive
If you have followed the above steps and you continue to experience the same issue, unfortunately it is likely that the hard disk drive is bad or the controller is bad.
If available, you may want to connect another known good hard disk drive to the computer to determine if it can be detected. If it is able to be detected then replace your hard disk drive. If it is not detected, unfortunately you will need to replace the motherboard or controller as it is bad.
If no additional hard disk drive is available it is recommended that the hard disk drive be replaced first or that the computer be serviced / repaired.
Jul 01, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
SATA Hard drive caddy not acknowledged
Yes, what it seems to me is that you have alot of devices connected and windows by default trie to give the same device the same letter every time you connect it. Well if something else takes its place and you try and connect it, it tried to give it that letter but cant and kind of sits in limbo in the device manager.
Try the following.
Right click " My Computer" and select " MANAGE"
Then when that opens, select the " Disk management" on the left side of the sectioned window.
On the right it should populate your drives including the one that you said isnt showing.
See what letter it is assigned. You can change the drive letter by selecting the drive on the right side, right click and change drive letter to somehting that you know isnt being used like " Z " .
Confirme, or O.K. it and then if all goes well, it should auto detect and it should show under my computer.
This often happens with windows when there is alot of similar devices connected. Windows can only handle up to 32 devices being connected at one time and soem times it holds onto a drive letter for another device and cant give it out to another. often devices such as External hard drives will also try to reclaim the same drive letter and will fight over it. Windows bassically just ignores it since it already gave out the letter to another device and you have to specify it another one.
Let me know if this works or if you need more help.
Feb 11, 2009 | Acer Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
139 people viewed this question
Alun Cox
