Question about Dryers
Dryer comes on, dryer turns, dryer heats but does
Electric Dryer comes on, drum turns, dryer heats but does not dry? what am I doing wrong. will only run about 15 - 20 minutes and the buzzer goes off but the clothes are not dry.
  • Anonymous Mar 24, 2014
    Clothes still dry for 20 minute
  • 163 Answers
Make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Posted on Mar 10, 2009
I khave a Kenmore gas dryer 110-90 series. It no longer clicks off when the timer is set. Now, there is no heat coming from the dryer. The drum turns with air drying but no heat from any of the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 19, 2011 | Dryers
Drum goes around but no heat clothes do not get
heatman101
Jun 16, 2011 | Maytag MED5600TQ Electric Dryer
DRYER IS NOT HEATING BUT DRUM IS RUNNING BUT NOT DRYING
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 09, 2011 | Miele Novotronic T1515A Electric Dryer
I have and electric estate dryer. The drum is turning but the clothes are't getting dried in the automatic cycle or timed cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 14, 2010 | Estate TGDS840JQ Gas Dryer
The dryer no longer dries WITH heat. The drum turns, everything else seems in order. How do I check if I need a new thermostat?
heatman101
Aug 11, 2010 | Maytag Dryers
Why won't my dryer heat up and dry clothes. The light comes on and the drum turns, but no heat comes from the dryer. It is a gas dryer and there is gas available. The settings are in the same cycles I've...
heatman101
Aug 01, 2010 | Whirlpool LGR7646E Dryer
Heat is not always coming on in dryer. Roper dryer from Lowes
There are numerous temperature sensors on the dryer. Some are near the drum, some could be near the lint filter if it is located inside the dryer door. Try changing these first as they are an in expensive fix. It could also be the heating coils themselves. Highly unlikely it would be the dial, unless the dial was accidentally turned in the wrong direction.
Apr 26, 2010 | Roper REX4634KQ Electric Dryer
The dryer drum moves but no heat. Clothes do not
most of the time it is the heating coil their is a
series of springs the heat up and then the blower
sends air pass them and into the dryer to dry the clothes
you will need to remove the back of the dryer
and get to the heating element and look at it
and see it any of the springs are broken
cost for the part 80.00 maybe
good luck
Jan 10, 2010 | Zanussi TC7102W Electric Dryer
Drum is not turning. Heat works
Sounds like the belt has broken or come off. This is usually inexpensive to fix. You just need to get it out in the open to replace.
May 25, 2008 | Asko T761 Electric Dryer
Dryers Logo
183 people viewed this question
Top Dryers Experts
