Question about Mitsubishi WS-55859 55" Rear Projection Television
Need new bulb for TV
My brother has a Mitsubishi TV 52" 0r 56" and the round bulb with a handle on it blue out due to improper guidence from a teck from DISH NETWORK. Where can he purchase a new bulb. He lives in Roanoke, Va. Jeff
  • 40 Answers
You need to get the model # off the back. if its a 5252 it may be more then your bulb.. need more info
but google the model # and you will find a lamp
Posted on Mar 10, 2009
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
My 2002 honda shadow's front end wobbles badly when I take my hands off of the handle bars.
Hi, Anonymous and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Handlebars wobble when take my hands off Anyone know why motorcycles
Wobble
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Oct 24, 2013 | 2002 Honda VT 1100 C Shadow Spirit
2004 Honda VTX 1800 front end tends to loose traction in corners @
Hi, Peter and the usual suspects are:
14. Loose spokes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
VTX 1800 Handling Problems
http://www.triketalk.com/forum/archive/index.php/t-1065.html Honda VTX1800R Owner Manual service manual, not owners. https://www.partsfish.com/page/oem-parts-for-honda
May 10, 2012 | 2004 Honda VTX 1800
We have a mitsubishi 735 series tv. When we power it on the mitsubishi sign comes on then the tv shuts off. We replaced the lamp bulb but that wasn't the problem. Any suggestions
Most of these sets that come on with the blue screen and logo and shut off shortly after may have two resets---I can tell you the soft reset.
Turn set on with the Mitsubishi remote and when screen comes up blue with logo:
Menu, 1,2,3 enter
This applies to most of these sets.
Mar 14, 2012 | Mitsubishi WD-60735 Projection Television
_why would my tv blow the bulb and when i out the new one it it blew after about two hours
Two possible reasons. One, - what ever caused the original bulb to blow ( a defect in the tv ) blew the second bulb.
Two, - If the bulb was bumbled around a lot during shipping or handled ruff at some point it can cause it to blow before its time. This is the reason when you buy a demo tv sometimes the bulb will go fast due to the way its knocked around on the way to your home.
Jan 20, 2011 | Mitsubishi WD-57733 57" HDTV
My Mitsubishi VS-50705 is dark on screen, do I need to replace the bulbs to fix it? where to buy the bulbs? Thanks
There are no bulbs in this set. Only 3 crts red,blue and green. crts are probably going out. repair expense will exceed value due to age.
Dec 06, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Red shadow
ITS A 2003 HD MODEL,REPAIRING WOULD COST 250.00-350.00 WHICH SEEMS A LOT BETTER THEN BUYING A NEW TV. I RECOMMEND THE HIGHER REPAIR AND GET THE ORIGINAL MITSUBISHI IC'S.
May 31, 2009 | Mitsubishi WS-55513 55" Rear Projection...
How to change the headlight bulb on a 2001 mitsubishi galant?
On either side of the headlight wiring assembly, in the engine compartment, you will find 2 small tabs. They are located to the sides and towards the bulb of the plastic assembly. Press these 2 tabs in while pulling the wire assembly out. Remove the rubber gasket and unhook the wire spring holding the bulb in place. The bulb come right out. The bulbs are halogen so do not handle the new bulb by the glass.
Mar 04, 2009 | 2001 Mitsubishi Galant
50" Samsung DLP TV turns on get sound and picture for 1-2 sec then goes to standby
new bulbs can leak on your pc board if not installed correctly and the fluid starts to short things out... triggers the error message.
remember always check the last thing you did before having problems.
Jan 11, 2008 | Samsung DLP HL-P5663W 56" TV
Mitsubishi vs45609
have a tech check your tv it might need to be repair the problem could be in the color circuit.
Apr 18, 2007 | Mitsubishi VS-45609 TV
Mitsubishi WS-55859 55" Rear Projection Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
