Question about Marantz Audio Players & Recorders
Marantz CDR 615: Msg: ''No CD''
When inserting a recorded CD, I get message ''No CD''
Any idea?
Thanks!
I've owned one for years, and yes... depending on how many discs you burn, you may need a new tray. You can call Marantz and they will ship one to you. They will also send you a diagram of how to replace it. Pretty simple.
Posted on Aug 16, 2009
Will not burn a CD
Have you checked which CDR media the device can use.
This may be as simple as using a CD-R rather than a CD+R or vice versa,
Also check if you may be burning to a CDRW or CDR.
Apr 03, 2014 | Marantz CDR420 CD Recorder
When I insert a blank disk, Im getting a message saying "No audio". and nothing will record. Wot to do???
It's a data disc, not the required CDR-AUDIO or -MUSIC disk it needs to record.
Feb 16, 2011 | Marantz DR-700 CD Player
Hi have just bought this used item ,no manual unfortunately,but have tried 2 diff.CDR recordable discs & all i get after reading is,wrong disc & use audio cd, hope you can shed some...
There are 2 types of recorders. Professional, which you can use any kinds of cdr blanks and the Consumer, which requires to use
"Audio or Music only" discs and harder to obtain locally nowadays, but probably plenty on line.
Oct 04, 2010 | Marantz DR-6000 CD Player
I have a Marantz CDR 615 and it won't let me record anything-any help would begreat thanks
What kind of error are you getting? Does it attempt to calibrate then display the entire disc as being full? If that try a blank that will tolerate recording at the 1x speed. Nowadays the only thing you will likely find are discs meant for audio recording or data discs that can record at speeds as low as 1x. If you can find some of the earlier kodak, Ampex/Quantegy, japanese maxells, etc then you will be okay. Also it may not be obvious but the cdr 615/620 will not record on cd-rw's
I bought one of those new and had nothing but trouble out of the phillips cdd2000 module that had to be replaced 3 times (3rd time at my expense of $300) but Superscope in Aurora, IL was good about support. Ironically I seam to remember a class action suit against Phillips over their very flaky cdd2000 drives.
Oct 01, 2010 | Marantz CDR631 CD Recorder
Marantz CDR-510: Playback is good , recording is distorted
If this brand of media is new to you and the symptom is unique to it, I'd try a different brand.
Monitoring during record would never reveal media problems as there is no immediate playback after record as on old-school 3-head tape recorders.
I've had similar intermittent problems and I never could find a pattern to it except that it always seemed to be on low-end media. My best advice would be to try to find a pattern in your instance and make a change that avoids it. Then publish what you learned for us.
Good luck.
Mar 14, 2010 | Marantz CDR510 2-Disc CD Recorder
CDR tray
it's more than likely the servo board which is fixed under the mechanism.
this is very common but i'm not sure which component fails on the board but i've always got hold of donor recorders and switched the servo boards and all was fine.
Sep 06, 2009 | Marantz CDR500 2-Disc CD Recorder
I recently purchased a used Marantz CDR300 CD Recorder. Everything powers on but when I put a cd in the tray, it doesn't close automatically when I press the close button and when I manually close it, the...
CDR error means the trouble is in the laser eye,maybe the eye is faulty already or dirty. If the laser eye is dirty,then you need to clean it with a cotton buds.Open the unit then wipe the laser eye tenderly with the cotton buds or buy a DVD / CD cleaner kit.Just click this link;
http://electronics.bizrate.com/search__SEARCH_GO--GO__SEARCH_GO.x--36__SEARCH_GO.y--16__keyword--dvd+lens+cleaner__search_box--1__sfsk--1.html
Hope its help:
Regards;
VOTIT
Jun 27, 2009 | Marantz CDR-300 CD Recorder
Marantz CDR633
Try the following link.The manual will be automatically downloaded once the link is clicked.
click here for the manual of Marantz CDR
Good luck.please do rate my answer if accepted.Also feel free to post further comments.
Jan 18, 2009 | Marantz CDR632 CD Recorder CDR-RW with...
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
725 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
